Mirror Tilts Down _AND_INWARD_ !!
Original_black_bart
1 Post
The passenger side mirror of my 2005 Acura TL suddenly started tilting inward as well as down when the car is placed into reverse. I know the mirror should tilt down when the transmission is placed into reverse however I've never had it tilt inward before! The resulting position of the mirror makes it impossible to use as all I'm only able to see is the door of the car!
I tried adjusting mirror position then saving it with the driver memory function "Memo 1". It appears settings cannot be saved with the vehicle in reverse as the "beep" I normally hear when settings are saved is absent and the mirror settings are not saved.
The drivers side mirror works fine; when the option switch is placed in the "L" position and the transmission placed into reverse, the left mirror only tilts down as it should.
I've been driving the car for five years and during that time have become very dependent on right side mirror tilt. How can I fix this issue?
Original_black_bart
1 Post
I seem to recall a small amount of inward tilt. As a matter of fact the drivers side mirror does tilt in just a hair. Unfortunately the passenger side mirror tilts so far inward that I can't see the rear of the car. All I see is the drivers side door handle!
Original_black_bart
1 Post
Problem Resolved
Level: Noob
Is it hard to replace? Both of mine are broken. Sometimes, when I'm on the freeway, they'll both turn down and in to the door handles, and then do this weird thing where they keep trying to go farther and bounce back over and over.
ITSJESTER
17
12-06-2018 02:29 AM
soupi
14
11-15-2015 11:15 AM
