Mirror Making Weird Sounds When Car In Reverse
Old Sep 2, 2010 | 08:42 PM
Riga89's Avatar
B A N N E D
When I put my car in reverse the automatic tilt in the side view mirror is making some weird sounds. Sometimes it struggles to tilt down and other times it won't tilt at all. This is really bugging me. HELP!!
Old Sep 2, 2010 | 10:27 PM
Will Y.'s Avatar
Registered but harmless
The next time you are stopped in the TL for a couple of minutes, turn each mirror to the limit of its travel in each direction, then return it to the preset position.
See if that clears up the problem.
If not, the mirror actuator(s) will need replacement; there is a TSB on the problem and it should be covered under warranty for your year.
Old Sep 2, 2010 | 10:33 PM
Riga89's Avatar
B A N N E D
Thanks man. I may be out of warranty. I'm over the 60k mile mark. I will try though. Do you have a link to the TSB?
Feb 25, 2020 09:57 AM
tonio
Feb 5, 2019 05:43 PM
Rocktman1
Oct 31, 2015 02:33 PM
Mike Bertram
Sep 10, 2015 09:27 AM
Mcj270
Aug 31, 2015 04:45 PM
