Metallic, scratching sound- front passenger wheel
Old Jun 16, 2008 | 01:53 PM
ross7778's Avatar
I just purchased a used 2005 TL with 31,000 miles. When the car is moving forward from a complete stop there is a metallic, scratching sound coming from the front passenger tire. Like dragging a rake accross metal. This happens without using the brakes. The dealer hasn't been able to figure it out so they are sending it to an Acura dealer.
Has anyone else experienced something like this? I've read a few posts about squealing sounds when braking but it seems like my issue is different.
Old Jun 16, 2008 | 02:14 PM
01tl4tl's Avatar
has anyone checked the brakes???
Old Jun 16, 2008 | 04:03 PM
Legend2TL's Avatar
AZ Community Team
Could be the metal wear sensor on the front brake pads is touching down on the rotor. Check the brake pads on the front. If it's the sensor rubbing don't worry since they cause no damage to the rotor, but you need new pads. If the pads are worn to the metal, then it means you probably need rotors and pads.
More than likely it's the wear sensor, on Honda's and Acura's sometimes they just barely touch even with no foot on the brake pad.
Old Jun 16, 2008 | 07:58 PM
ross7778's Avatar
Well they disassembled the entire thing and determined that there was something loose rubbing on the rotor. The noise is gone.
Old Jun 16, 2008 | 08:10 PM
MrHeeltoe's Avatar
Former Sponsor
I've seen that happen. Pebble cause between rotor shield and rotor....makes a terrible noise!!!!
Old Jun 17, 2008 | 08:50 AM
korrupted's Avatar
J35A8
Also if the caliper seizes after awhile you'll start hearing the most annoying sound.
Old Jun 17, 2008 | 10:17 AM
MrHeeltoe's Avatar
Former Sponsor
Haha, yeah thats usually the brake pad backing plates grinding the rotor into fine dust.
BEWARE OF OVER-EXCESSIVE BRAKE DUST BUILDUP ON YOUR WHEELS, FOLKS! Its a sign of a sticking caliper.
Marcus
Old Jun 17, 2008 | 10:26 AM
korrupted's Avatar
J35A8
So does that mean the calipers on all the 3G TL-S are sticking
Feb 25, 2020 09:57 AM
GhostTL09
Sep 19, 2015 01:57 PM
Ny1718
Sep 11, 2015 09:21 AM
08 NBP TL
Sep 8, 2015 08:49 PM
asahrts
Sep 4, 2015 05:55 PM
