Memory Seats & Mirrors
Old Apr 6, 2014 | 12:32 PM
jpm3071's Avatar
Talking Memory Seats & Mirrors
Hi Guys,
Memory Seats and Mirrors randomly stopped working. They work manually but they dont adjust to my settings when I first enter the car.
I looked at the manual, checked the fuses and haven't seen anything blown. Any ideas?
Old Apr 6, 2014 | 01:17 PM
bla8291's Avatar
Does the MIL still say Welcome Driver X? If not, your remote was probably unlinked. There are instructions on the back on the remote to relink it.
Old Apr 7, 2014 | 12:32 PM
jpm3071's Avatar
The MIL days Driver 2 detected when I get into the car
Old Apr 7, 2014 | 10:16 PM
subinf's Avatar
One on the right for me
I have the same problem. I haven't found a solution. Mainly because I haven't really done anything about it.
Old Apr 8, 2014 | 06:51 AM
rubenders's Avatar
performace tl-s
your problem is one of your side mirros sensor is bad so the memo system stop working
Old Apr 8, 2014 | 08:05 AM
jpm3071's Avatar
Really? Im assuming you've gone through this before?
Old Apr 8, 2014 | 09:27 AM
acrdr's Avatar
replace your mirror actuators
might as well replace both of them
the work together with memory system
common thing to fail and cause memory system issues
Old Apr 8, 2014 | 10:57 AM
jpm3071's Avatar
Cool thanks
Old Apr 8, 2014 | 12:09 PM
subinf's Avatar
Glad I saw this the thread.
Old Apr 8, 2014 | 07:43 PM
iHeartmyHonda's Avatar
I too just experienced the same problem when i went to program the seats, then the door remote just stopped working all together.
Also, if i have the mirror select switch set to center and i put my car in reverse, the drivers side mirror doesnt set back into the original position when i shift into drive.
any ideas? same problem as op?
Old Apr 9, 2014 | 07:28 PM
homeboynyc's Avatar
Hi guys, I have a similar problem, the memory seat works when it wants to and the mirrors only bottom and to the right no left or up, replaced both switches and still doing same thing, checked car for any wires touching or anything and couldn't find anything, after unplugging the connector on door and put back on memory seat was working for a bit then it stopped again.
Old Apr 9, 2014 | 09:42 PM
rubenders's Avatar
performace tl-s
Yes I did.
Old Apr 9, 2014 | 10:44 PM
Will Y.'s Avatar
Registered but harmless
Pull fuse #20 in the inside fuse box by the driver's left knee-- it should be a 7.5 Amp-- and replace it with a 10 Amp fuse per the TSB issued several years ago. It's a pretty common issue.
Old Apr 10, 2014 | 05:59 AM
homeboynyc's Avatar
Will try that, thank you very much bro.
Old Apr 10, 2014 | 11:07 PM
homeboynyc's Avatar
It worked guys!!!! Ty bro
Old Apr 11, 2014 | 12:14 AM
subinf's Avatar
Thats even better
Old Apr 12, 2014 | 11:53 PM
navarretg's Avatar
2004 Acura TL
I had the same problem a day ago when I started messing around with my mirrors... The lesson to be learned is "if it ain't broke, don't fix it"
I replaced my mirror actuator by the way and that solved OPs issue
MrHeeltoe
20
Feb 23, 2023 01:54 PM
tsx_boy
Dec 13, 2019 08:33 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
soupi
14
Nov 15, 2015 11:15 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
