Memory seat not moving
Old Sep 11, 2013 | 09:10 PM
Rita Gallion's Avatar
Got my 2007 TL Saturday. The memory seats will not program. When I get in or out the seat does not move. I can use the side buttons to fwd and back, the lumbar adjusts and the back of the seat will up and down. The front part of the seat will not adjust. It clicks but not move. Is that why the memory will not program?
Old Sep 16, 2013 | 09:06 PM
LoveMyTL-S's Avatar
I'm assuming your "Driver 1". After you adjust the seat, mirrors, etc, you press the Driver 1 button on the door and then the save (memory) button and nothing happens?
Old Sep 20, 2013 | 09:17 AM
when I open the door to get in, nothing moves. Seats, mirrors, telescoping steering wheel, whatever else is supposed to move. The display says "welcome driver 1". I have positioned everything the way I want and press the mem button and the button 1 to program. Everything works manually except for the front up and down of the seat.
Old Sep 20, 2013 | 11:52 AM
Will Y.'s Avatar
Registered but harmless
Try this: get in the car, just move the seat to the rear and recline the back without touching the memory buttons.
Get out of the car and lock your doors.
Then use your remote to unlock the doors and open the driver's door.
Does the seat move to your prior position?
If yes, the DPMS/memory functions are working, and you can program the driver, external mirror, audio and climate settings for each remote.
Get back to us if the seat does not move upon opening the door.
FYI, the steering telescoping function is manual only, via a lever, and is not motorized.
Old Sep 21, 2013 | 11:25 AM
Ok tried it. Seat back moves, up and down back part of seat, mirrors move. Does not slide forward and the front of the seat does not move
Old Sep 23, 2013 | 12:55 PM
Will Y.'s Avatar
Do your windshield washer fluid pump and interior auto-dimming rear view mirror work now?
If not, pull the 7.5 Amp fuse in #20 in the under-dash fuse box on the driver's side and replace it with a 10 Amp fuse-- there was a TSB specifying that upgrade.
Old Oct 2, 2013 | 07:29 PM
yes, those items work fine. just the front of the seat up and down doesn't work.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
tsx_boy
Dec 13, 2019 08:33 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
