Lower passenger ball joint
Old Nov 1, 2018 | 08:20 PM
BigA1987's Avatar
So the lower ball joint on the passenger side literally just broke. Are they hard to replace? I'm a former technician so I have all the tools and know how just wondering if there is anything to look out for or anything that makes it a pain in the butt.
Old Nov 1, 2018 | 10:27 PM
peter6's Avatar
Well... you know that it's pressed in into the knuckle, right?
Never did one on TL, but that should be the process.
Old Nov 2, 2018 | 12:01 AM
Duronn's Avatar
5lb hammer & brute force...LOL
Old Nov 2, 2018 | 09:33 PM
champaned_out's Avatar
and even then im promise it'll give you problems.. i attempted to remove the ball joints off the LCA a few months back.. borrowed the ball joint press kit from autozone just to find out EVERY single cup they had didnt fit either side to press the ball joint out.. you would need to either look for another ball joint press kit other than auto zones or you can buy the honda oem press kit although it is pretty pricey
I ended up just going to a independent shop and got it pressed out for like $20
Old Nov 4, 2018 | 08:45 AM
BigA1987's Avatar
Done
Got it done. Was fairly easy and straight forward. The abs speed sensor broke of course but just drilled it out and replaced with new one. O'Reilly has the Honda specific cups to rent. $120 but you get the depoade back so it's not a big deal. ABS sensor was kind of pricy... They must break on that side a lot. It was double the price of all the other ones.
Old Nov 4, 2018 | 09:04 AM
nfnsquared's Avatar
^^^You couldn't disconnect the ABS wiring in the engine compartment?
How many miles on the LBJ? Did it break while you were driving?
Old Nov 4, 2018 | 09:52 AM
BigA1987's Avatar
Honestly I did not think about disconnecting it inside the cab. that lower ball joint has been replaced before so it really didn't have that many miles on it I'm assuming the shop who did it before used a cheap part. Yes it did happen while I was driving but just in a parking lot so thank God I wasn't on the freeway
Carmodifier
Jun 29, 2010 02:18 PM
qstorm78
Mar 29, 2007 05:04 PM
5-speed
Feb 4, 2007 10:21 PM
pi1996
1G TL Problems & Fixes
Jan 8, 2006 04:12 PM
canadiantoy
Apr 22, 2005 08:14 AM
