Loud Thunk at start up
Old Jan 19, 2010 | 09:14 PM
KC CL 1785's Avatar
cmng 2 a lawschool near u
Exclamation Loud Thunk at start up
Hi Everyone,
I bought a 2008 TL Type S last Wednesday and there are a few things that I've noticed.
1. When I start the car there is a "thunk" sound that I hear and feel in the brake pedal/driver's side floor board. I've done several searches but I cant find a thread for this, is this normal or should I have the dealer check this out.
2. I was told there is a slight pull to the left when I accelerate...there is but it also feels like the alignment is off as it pulls to the right when I am coasting...
Any ideas would be greatly appreciated.
Old Jan 19, 2010 | 09:18 PM
1fsthatch's Avatar
bring it to the dealer did you buy it at an acura dealer?
Old Jan 19, 2010 | 11:14 PM
Will Y.'s Avatar
Registered but harmless
Probably the ABS self-check, which is a single "thunk" in the lines.
Not good-- check the COLD tire pressures if you haven't already.
Also, look at the front tires for any unusual wear pattern.
Possibilities are a bad alignment, bad tire(s), bent suspension or subframe.
Swap the front and rear tires-- is there any change? If so, the tires are the cause.
If not, it's more likely the alignment. Have an alignment shop do a proper alignment to eliminate a bent suspension or subframe issue.
Old Jan 19, 2010 | 11:29 PM
KC CL 1785's Avatar
If I purchased a certified acura, wouldnt that eliminate the bent frame? Also, I believe its more of a thunk versus a loud thunk...
pstomps
Feb 20, 2017 03:29 AM
obert
Dec 14, 2015 11:36 PM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
Hau_nguyen91
Sep 6, 2015 12:53 PM
jordanboi
Sep 5, 2015 01:33 AM
