My 2004 Acura TL is at 176.000 miles, has had all engine mounts replaced as well as a new (used) trany installed. NOW, it just about a week ago gave off a loud POP which I felt while driving. After inspection, nothing found. My car has been squeaking for some time but now when I pull out of my garage and turn or pull into a parking spot, it is making such a loud cracking noise, I have no idea what it could be. Defiantly metal noise. Any ideas???
thoiboi
close
- Join DateApr 2010
- LocationSoCal, CA
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:9,170 Times in 7,045 Posts
Axles?
Would they make such a loud CRACK CRACK CRACK? Also, would they be the cause of the squeaky spring noise while turning. I have had the squeak for about the last year and the cracks are new.
thoiboi
close
- Join DateApr 2010
- LocationSoCal, CA
Squeaky spring sounds like your suspension is failing.
also inspect your motor mounts.. my old accord had 2 broken engine mounts and made a loud clunking noise whenever i was doing low speed turns
thoiboi
close
- Join DateApr 2010
- LocationSoCal, CA
Quote:
Quote:
Originally Posted by bethknvygrl24
My 2004 Acura TL is at 176.000 miles, has had all engine mounts replaced as well as a new (used) trany installed?
nist7
close
- Join DateJun 2010
- LocationKansas City
- Age40
Liked:1,095 Times in 750 Posts
Just throwing this out there...but when I had my 1995 Accord (I took a turn too fast in the wet) and it popped the sway bar end links out and the axle area would make these really nasty loud crack/pop noises whenever I turned. So something to think about from my own personal experience. Hope you get the issue ID'ed soon!
Thank all for the replies! I'm going to get it looked at this next week as I have a 5 hour drive through the mountains to make at the end of the month and last time I drove it, my transmission went out. I will keep you guys posted! :-)
P.S I will be sure to mention those things that you guys suggested!
csmeance
close
- Join DateFeb 2006
- LocationSpace Coast, FL
Liked:2,181 Times in 1,566 Posts
cracking sound could be a bad ball joint and it failing would be very bad on your trip!!!! Get it checked out asap!!!Originally Posted by bethknvygrl24
Thank all for the replies! I'm going to get it looked at this next week as I have a 5 hour drive through the mountains to make at the end of the month and last time I drove it, my transmission went out. I will keep you guys posted! :-)P.S I will be sure to mention those things that you guys suggested!
