Loose Front Strut Bar
Old Nov 2, 2011 | 03:41 AM
TheChamp531's Avatar
Chapter Leader (San Antonio)
Will it damage anything? When I re-installed my suspension, the bolts that holds the right-side strut bar just gave out on me. The screw just ripped in half (cheap steel ftw). It's been making a 'wobbly' noise, but besides that it seems fine. Also my emergency brake doesn't work, anyone having a similar problem?
Old Nov 2, 2011 | 05:29 AM
CLtotheTL32's Avatar
I only have two bolts holding my front strut bar on each side and it's been like that for almost two years. When I did my suspension swap, I stripped the bolts trying to take them off. You should be alright.
My handbrake doesn't work as well as it used to either. I can't help you out there but I'm looking forward to seeing if anyone has any suggestions.
Old Nov 2, 2011 | 08:37 AM
jokerman826's Avatar
Jokerman
one of two things for your e-brake. 1. The cable needs to be tightened, you have to remover the rear part of the center console to get to the adjustment nut. 2. Your brake shoes for the e-brake are worn down too much.
Old Nov 2, 2011 | 09:20 AM
TLDude876's Avatar
Chapter Leader (Houston)
Strut bar should be fine. As for e brake, you can try adjusting via center console and if that doesnt work, tighten it via the hub in the rear. There is a rubber cover on the front of the rotor, pop that out and you'll see where needs to be tightened
Old Nov 2, 2011 | 12:24 PM
Thanks for the help. I think it may be the brake shoes, because I can drive with my e-brake on. :/
Old Nov 2, 2011 | 08:03 PM
guitarplayer16's Avatar
That's your problem right there.
marcelft
Jul 10, 2018 06:17 PM
acurajj
Feb 14, 2016 02:28 PM
o8 ENVII 8o
Nov 30, 2015 04:23 PM
Heyzuez20
Oct 14, 2015 07:18 AM
08 NBP TL
Sep 8, 2015 08:49 PM
