Locked engine won't crank-HELP!!!
Old Jul 14, 2011 | 09:17 AM
josiel's Avatar
Two days ago my car started miss firing I checked all sparkplugs, ignition coils and everything was fine so I went on with a compression check and one of the cylinders came up with 0psi, I called a few friends and they all said it was probably a clogged valve so I did the seafoam treatment but nothing happened, yesterday night as I was heading home it started miss firing more until it turned off I tried to start it and it would crank but not start, after a few times of trying it started but I couldn't let it drop under 2k or it would turn of I drove about 5 miles like that until I heard a big clanking noise and the car shut off and now it won't even crank the engine is locked, this morning I removed the 3 front spark plugs 2 of them were filled with oil and one was all torn up then I removed the intake manifold and it was filled with oil mixed with water and had a few pieces of metal in it, let me know what you guys think I really need help on this to decide what to do. Sorry for spelling I'm writing on my phone please help!!
Old Jul 14, 2011 | 09:19 AM
over-rev.
Old Jul 14, 2011 | 09:23 AM
jda123's Avatar
Dogmatic Dinosaur
So many things could be wrong
Could be a broken cam, valve, value spring, piston, piston ring, cracked head, etc... or a combo of any of them. No way to know until you get in there.
You are going to need to take off the valve cover and have a look at the cam, springs and valve stems and inspect the head from the top end. If that all looks fine, then the head is going to need to come off, but it is probably going to need to come off anyway.
Unless you are under warranty, then this is not going to be cheap. Sorry.
Old Jul 14, 2011 | 09:33 AM
josiel's Avatar
I've never over reved it but don't know of the previous owner did?? ill be removing the heads this afternoon see what's wrong, is there any chance it went off timing, and if there's any bent rods or cracked piston what do you guys recommend getting a new engine or rebuild this one
Old Jul 14, 2011 | 09:48 AM
jda123's Avatar
Dogmatic Dinosaur
You need to see what it wrong first. There is no way to know yet.
Old Jul 14, 2011 | 09:55 AM
josiel's Avatar
I'll keep you guys posted after I remove the heads, thanks
Old Jul 14, 2011 | 01:55 PM
josiel's Avatar
Anyone else have any thoughts?
Old Jul 14, 2011 | 06:48 PM
josiel's Avatar
Uploaded with ImageShack.us
Things are way worse than i thought, its time for a new engine
josiel's Avatar
please give me ideas on what to do thanks
Old Jul 14, 2011 | 07:46 PM
I hate cars's Avatar
You threw a rod. Notice the missing piston lol. Engine is junk. Replace entire engine. If you're lucky you can reuse the heads after rebuilding and resurfacing.
You drove the car around with 0psi on one cylinder, what did you think would happen? There's no such thing as a "clogged valve".
You've got part of an oil ring sitting on the head, a piece of wristpin and rod and 1/4 of the piston ring land area sitting on the crank. There's most likely a hole in the block where part of the rod exited but maybe not since the top of the rod is still inside of the engine. Just the fact that the piston top and top of the rod are sitting on the crank, you might've broken the crank too.
Old Jul 14, 2011 | 07:55 PM
If it's locked up it would be all of those broken pieces wedged between the block and the crank. Highly unlikely anything is usable. After seeing the huge gash in the head, it's not usable either. More than likely you dropped that valve into the combustion chamber, kept driving until it destroyed the piston which let the rod self destruct.
Old Jul 14, 2011 | 08:05 PM
josiel's Avatar
tomorrow ill be bringing down the engine i found a j32a3 in a local junkyard with 65k theyre asking $900 for it, i havent seen it yet but i will come by the place tomorrow and take a look at it. what do you think? is it worth repairing? most of the valve was inside the intake manifold
Old Jul 14, 2011 | 08:14 PM
I would get the junkyard engine for $900 as long as it's good.
For a rebuild you're looking at:
At least one replacement fully dressed head.
At least one piston, pin, and ring set.
At least one rod.
Gaskets and misc along with machine work and labor which is extensive.
That's the absolute best case scenario. Most likely you will need a new block and about 50/50% chance of a new crank depending on whether or not the big end of the rod held together. There's also the chance that everything exited through the oil pan.
Old Jul 14, 2011 | 08:19 PM
josiel's Avatar
i guess my best choice is to go with a new engine. im pretty sure any engine i find came of a AT Tl would i have to change the wiring on the engine
Old Jul 15, 2011 | 07:29 PM
josiel's Avatar
my yard looks like a junkyard lol. so i went and bought this engine it came off a totaled 04 tl it has about 65k on it and 90 day warranty what do you guys think?
Old Jul 15, 2011 | 09:40 PM
04WDPSeDaN's Avatar
iWhine S/C 6MT TL
You know with 0 psi you should have heard "some" metallic noise before the engine gave out. Either way with the new engine you should do the timing belt with water pump and tensioner while it's still out of the vehicle. T-belts due every 6 years or 105k.
Old Jul 15, 2011 | 09:48 PM
josiel's Avatar
im also going ahead to order new engine mounts (still deciding which to go with) while i wait for them to arrive ill be doing a full service to this engine to make sure nothing goes wrong once it starts
Old Jul 16, 2011 | 07:55 PM
josiel's Avatar
so today i got the engine out i spent about 8 hours to remove it, tomorrow ill be putting the MT wiring and will be swapping the transmission
Old Jul 16, 2011 | 07:58 PM
josiel's Avatar
Old Jul 16, 2011 | 08:00 PM
COOOOL!
looks like a fun project!
Old Jul 16, 2011 | 08:21 PM
KN_TL's Avatar
Man, with that much damage, the engine had to be singing like a dude that was just kicked in the nads.
Looking at these pictures has made me so happy I now have a lift. It's going to be so much easier to do my clutch swap.
Old Jul 16, 2011 | 10:44 PM
guitarplayer16's Avatar
Keep us updated!
Nice find on the new engine =)
Old Jul 16, 2011 | 10:59 PM
hydrolocked?
Old Jul 17, 2011 | 06:07 PM
josiel's Avatar
im guessing it had to be hydrolocked, because what else can cause a damage like this when everything was working perfectly. The missfiring started one day when i turned it on in the morning and from there 4 days later this happens, but it has been raining alot these days, if it were hydrolock wouldnt it happen instantly?
Old Jul 17, 2011 | 07:55 PM
If it hydrolocked bad enough to cause that you would have known it. It would require a puddle and it would have killed the engine. Besides, hydrolock doesn't explain the broken intake valve.
It might have dropped a valve down into the cylinder which would give you 0 compression then you kept on driving and it broke the piston which let everything loose.
Or detonation. Do you run premium?
Honestly you can see what looks like the imprint of an intake valve and seat in the head. It really looks like you hurt the valve first and the valve took out the piston. Anytime you have 0psi and no noise it's almost for sure valvetrain related. It's hard to get 0psi with a damaged piston unless it has a hole in it which usually makes noise. You can break a ring and ring land and compression will be very low but usually not at 0.
Old Jul 17, 2011 | 08:56 PM
josiel's Avatar
yes i always run premium, i think the problem was what your saying a broken valve that fell into the cylinder and i kept driving the car and thats what caused the piston to break and lock the engine
Old Jul 19, 2011 | 01:59 PM
SCS15's Avatar
Wow man that absolutely sucks to have happened but atleast you got a pretty good deal on the new engine. good luck with the swap.
Old Jul 19, 2011 | 02:31 PM
jda123's Avatar
Dogmatic Dinosaur
You are fortunate to have the time, inclination and ability to do this swap, otherwise you could be looking at 3-5K, or more.
My guess is that the an over-rev from the past did some damage and only recently broke all the way. I guess that it could have been a zero clearance valve issue with perhaps a broken timing belt in the past. In any case, this is perfect evidence that issues can arise down the road when metal gets with metal. Anybody who broke a timing belt and did not pull the head to have it fixed/checked, this could be in your future.
Could have been poorly adjusted valves too.
Old Jul 19, 2011 | 02:34 PM
lucnex's Avatar
Where Did My Garage Go?!!
how to heck did you get your car so high on those jackstands?!
Also looks like your compliance bushings on your LCAs are torn....may as well replace those while you have the entire car apart practically...
Old Jul 19, 2011 | 02:35 PM
MichaelBenz's Avatar
CTS-V Import Slayer
Could have told you that on your second post about...lol. Good luck man...that sucks!
Old Jul 19, 2011 | 03:30 PM
josiel's Avatar
i actually lifted the car with the crane to take the engine out through the bottom
Old Jul 19, 2011 | 03:31 PM
josiel's Avatar
yesterday i went by P2R and got a set of ported runners and ordered a motor mount kit from innovative they'll arrive tomorrow thats all i need to mount the engine
Old Jul 19, 2011 | 03:38 PM
Majofo's Avatar
yeah.. I think I see your problem.
Keep us updated.
Old Jul 21, 2011 | 04:42 PM
josiel's Avatar
well now i need a new clutch mine is kinda wasted it has 100k on it, i ordered the one from p2r what do you guys think
Old Jul 21, 2011 | 05:22 PM
josiel's Avatar
here are some pics of the runners my kinda worn clutch and the oil ill be using with new plugs
Old Jul 22, 2011 | 10:37 AM
CTS-V Import Slayer
Did you just seriously post a pic of oil, plugs, and an oil filter on the internet? Good to know you will be using those things...lol.
Old Jul 22, 2011 | 10:41 AM
lucnex's Avatar
hmmm why 5W-30 over 5W-20? Engine doesnt have too many miles on it...
Old Jul 22, 2011 | 12:04 PM
Bearcat94's Avatar
AZ Community Team
I prefer 5W-30 as well.
I like the idea of a slightly heavier film. I also subscribe the "5W-20 is for CAFE" theory.
Old Jul 22, 2011 | 12:59 PM
EagleEye's Avatar
You and compliance bushings Luc. Did you get yours fixed yet? It'll be much more stable on the highway. Mine used to randomly go left and right at 75+. I wish I found the Drew dude. Acura Libertyville took me to town for $600 bucks (3 on each arm). Machine shop was $100 bucks to remove and press new ones in. One problem I am having now is that my brand new Continental DWS are cupping Not sure if it was the 3-4K on the crappy broken bushings that caused it or if new ones were put in incorrectly.
BTW-check out the new site I am helping Drew with www.nnstudios.com/thepitshop_devdeploy/ That's how much I am standing by this guy.
Old Jul 22, 2011 | 01:02 PM
EagleEye's Avatar
Hey Bear - do you know which thread talks about the different motor oils in context of protection etc...? Seems to be scattered with IHC and those guys chiming in here and there.
Such a touch subject - everyone swears by some brand or weight. But from all the reading and some "studies" that I've read it's down to change your oil and filter every 3K and you're set (for normal driving).
