Leaking Radiator
Old May 1, 2007 | 07:42 PM
ltkaufman's Avatar
Leaking Radiator
Ok, this is a good one. 06 MT with 10K started noticing that the antifreeze level in the overflow bottle was going down. Added a bit but did not think much of it. After it continued to go down took it into dealership. After a few visits they noticed that the seals on the top and bottom tanks of the radiator were leaking. They indicated that they have seen this on 2 different MDX's but never on a TL. They ordered and installed a new radiator. About 1 week later, same problem. WTF. Acura needs to get their act together. If I wanted this quality I would have bought a FORD. Anyone else have this problem?
Old May 2, 2007 | 06:26 PM
Xx06SickspdTlxX's Avatar
06 TL 6spd. Navi/A-spec
Well you got the bad luck of the draw, the mechanics at your dealer should have made sure that it was fixed and done right the first time!
Old May 3, 2007 | 08:57 AM
ltkaufman's Avatar
Tell me a about it. They now have had my car for almost 1 week trying to track down the leak. They are flying an engineer in from CA to lend a hand. I think they believe this is a bigger issue. Will let know.
Old May 3, 2007 | 09:29 AM
rbf351's Avatar
Registered User
at least you have a leak, i have an 05 TL that stinks like antifreeze, but no one can find the leak
Mike734
Dec 10, 2021 01:25 PM
Avenger411
Oct 11, 2015 03:53 PM
steve
Sep 30, 2015 09:23 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
