Leaking motor mount
Old Apr 25, 2008 | 07:59 AM
runninlow3's Avatar
Leaking motor mount
My friend was performing a transmission fluid chnage on my '05 AT TL yesterday, when he noticed that the front motor mount had a slow fluid leak. He pointed out a ring of fluid around the mount. If you were to look from under the car at the cross member, where it mounts, you can see a ring of fluid.
My car has only 28,000 miles on it and I'm still covered under warranty, so I'm going to call Acura today and schedule an appointment.
I was curious...has anyone else had any problems with bad motor mounts/had them replaced? Is this a common issue?
Old Apr 30, 2008 | 10:27 PM
Tech7427's Avatar
Under your Acura...
yes, ive replaced a few.. yes they are fluid filled, and if they crack all the way through the fluid will leak out
Old May 14, 2008 | 01:17 PM
FLIPED WRX's Avatar
i've done couple of those with low mileage and ending up replacing under warranty
Old Nov 18, 2010 | 10:22 PM
jaycura's Avatar
I just replaced one at my 92,000 recommended maintenance.
Old Nov 19, 2010 | 04:18 AM
Indy04TL's Avatar
I replaced mine this past week and it has made all the difference in the ride and idle. I don't remember the car ever being this smooth. The people on here have done a great job on this subject. Just do a search on "motor mounts" and you will find more GOOD info on this subject than you thought existed!!
Old Nov 19, 2010 | 11:44 AM
hrod26's Avatar
Yes...they are a common problem. As Indy04TL said use the search function...ton of information out there. I have changed all three motor mounts myself with the DIY info out there
IBankMouse
Jun 13, 2020 12:53 PM
Jul 16, 2017 07:33 AM
juanrl
Sep 29, 2015 03:25 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
