Knocking problem when cold
Old Feb 8, 2016 | 08:02 PM
QuickTL07's Avatar
Hey guys,
I noticed on my 07 TL that im getting knocking when the car is cold, and it on the passenger side. I though it could be power staring pump, well I got that taken care of, it was the seals so I have replaced the item it was a cake, but now when the car is cold it still knocks, and when its warms up it goes away... Some times even when its cold doesn't do it.. its wired and strange,... what could it be?
Old Feb 9, 2016 | 12:20 PM
truonghthe's Avatar
Can you take a video for us?
Old Feb 9, 2016 | 12:22 PM
what kind of gas are you putting in?
A/C compressor?
Old Feb 9, 2016 | 02:53 PM
Turbonut's Avatar
Not really a knock, but serpentine tensioner pulley.
Remove the belt and start the car and see if noise is present and go from there.
Old Feb 11, 2016 | 11:58 AM
flyromeo3's Avatar
Just to add, when you remove the belt you'll have the battery light illuminate on the dash board.
but yes, follow Turbonut advice. That will help you narrow it down if its a pulley.
Old Feb 12, 2016 | 04:57 PM
QuickTL07's Avatar
Pully has been replaced, also i only use premium, What i didnt know my engine takes OIL!!! i dont know if thats normal on these engines or not, mine is 07 with 85k miles on it... soon timing belt will need to be replaced.
I added half q of 10w30 oil and it got a lot quieter...
Old Feb 12, 2016 | 04:58 PM
QuickTL07's Avatar
just to add, oil is faily clean, its not black or smoked black, just brown but on the dark side.
Old Feb 13, 2016 | 04:59 AM
Turbonut's Avatar
If it was only 1/2 qt. low, that won't change anything, but if it was empty, or near empty it would take a lot more than 1/2 qt. to get back to the capacity needed.
Old Feb 13, 2016 | 08:21 AM
stegey's Avatar
i agree i don't think 1/2 a quart is going to make a difference it would hv to be down at least 2 qts to hear anything. if you want to rule out external accesories wait till its making the noise and shut off immediately and take the belt off to see if there is a difference. i don't recall having any harmonic balancer issues with honda's of any kind. but that could make a knocking noise.
Old Feb 13, 2016 | 08:50 AM
Turbonut's Avatar
Good point as there have been cases of harmonic balancer separation, so that's another area to check.
Old Feb 23, 2016 | 12:32 AM
QuickTL07's Avatar
I just got my oil change done on my car, decided to go little thicker due to mileage on the car.. the i went with 10w30
The noise is still there, little less i will say... but its f-ing wired only when its cold, but when it warms up, problem goes away.. wired as hell and drives me nuts! I have a feeling i will need to take it in and adjust the lifters.
Old Feb 23, 2016 | 12:34 AM
QuickTL07's Avatar
I'm no mechanic, but if the harmonic balancer was the issue, don't you guys think I will hear the noise all the time, not just when it cold start?
Old Feb 23, 2016 | 01:02 AM
nfnsquared's Avatar
Only when cold? Valve/s??
You describe it as knocking... could it also be described as tapping (loose intake valve) or ticking (loose spark plug)?
Old Feb 23, 2016 | 07:19 AM
Turbonut's Avatar
As stated before, remove the serpentine belt and start the car.
Old Feb 23, 2016 | 11:08 AM
Afdeng5's Avatar
Is it a constant knock? When mine is cold and I am accelerating with the wheel cranked in either direction (as if pulling out of a parking spot or parking lot), I get a knocking sound until I straighten the wheel back out. Sounds like its coming from the wheel assembly or axel.....sounds like you're experiencing something different
Old Feb 23, 2016 | 12:00 PM
JasonK's Avatar
09 TL SH AWD /w TECH
Ticking will be low oil.
Whens the last time you did an oil change?
Knocking will either be your serpentine belt or timing belt. If it's coming from that area. Powersteering pumps do NOT knock they just whine when low on fluid or are failing.
Maybe your tensioner is all the way out and is no longer good so the belt is being flimsy. Harmonic balancer aka crank pulley can also make the noise. But you would also hear that when you just run the car and it would be all the time. Could also be in your timing area.
Best to take it to a mechanic.
waxy
May 4, 2016 09:19 AM
Evilocity
Apr 22, 2016 09:33 AM
mtiaz
Jan 24, 2016 11:21 AM
TLMichelle
1G TL (1996-1998)
Jan 20, 2016 11:56 AM
