Knocking Noise ???NOT AXLE?
OK I changed both axle's about 6 or 7 months ago ,now I notice that its making the same exact noise again when turing …the wired thing is ,its making the knockin noise when I turn left and right but noise is only coming from driver side only im sure off this case I jus spend the last 20 mins going around in counter clock wise and and clock wise circles …I have no idea what this is …if it is the axle again ..can a broken axle cause vibration in the wheels ..if u need me to make a video ill be happy too ..hope I get some help ..thanks to everyone thats gonna reply
3G TL/2G MDX Owner
could be the axle again. a bad inner CV can cause steering vibration with acceleration. the clicks or "knocks" usually outer CV. if you do a search there are a number of threads dealing with this type of issue. what did you replace your axles with??? some of the aftermarket axles are warrantied. if you're lowered...there could be issues there, but turbonut should be able to help you out with that.
CV is the part on the end of the axle that flexes. Constant Velocity joint.
You may have replaced yours with "reconditioned or re-manufactured"
ones. I've had bad luck with those & started getting "New C V Axles", no problems since on several different cars, all are Hondas & Acuras.
I guess ima have to replace the axle again =( …how long do u guys think I can drive on it wid the knocking noise starting a week or 2 ago….what happens when it totally breaks ?
Should I get a axle off this site http://www.wholesaleimportparts.com/..._Axle_2005.php
^I have heard "Raxles" is a good place, but you may want to contact them to see what you need to do, as far as a core exchange and what not. Let us know either way.
://www.raxles.com/
://www.raxles.com/
knocking noise when cold only going on 2 years now. Gonna check it out when I do the timing belt in the next month or 2.
3G TL/2G MDX Owner
you could drive with it awhile. it will only get worse. i drove with the "click" and the bad inner CV for at least a year....then it just got annoying knowing that my car was not behaving or handling the way it should. i had less than 45K when it first started...then had both replaced with OEM around 50K when i couldn't stand it anymore. especially with a new set of tires. good luck. definitely go brand new axles OEM or reputable aftermarket that isn't chinese made (i heard these were bad from the dealer and other members posts).
So turns out I did have wanrenty on that axle so I'll get my money back and I'll buy a new axle from advanceauto ..I been reading other threads and I seen that name a few time puls it has lifetime warranty i don't think I can go wrong
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
