Key Fob Not Working - Can't get into car
Old Jul 6, 2010 | 08:44 PM
TRainbow's Avatar
Key fob quit - I replaced the batteries in both but no luck. No outside key holes - how do i get into the car?? I'm guessing the car battery is dead, but can't do anything about it until I can get in the car. The freaking manual is in the car!
2006 TL
Old Jul 6, 2010 | 09:51 PM
AMUA6's Avatar
ScoobyZINE
You didn't put a "cheat" wire outside the car, since you don't have any keyholes? I'm not familiar with the "shaved key hole mod" but can't you just pop the cover off that hides the key hole?
Old Jul 6, 2010 | 10:07 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Old Jul 6, 2010 | 10:08 PM
Will Y.'s Avatar
Registered but harmless
Just pop the small end cap off the handle on the driver's side door using a small screwdriver-- as AMUA6 pointed out, a prior owner modded your TL by putting a rear door handle cap over the key hole.
If you break a tab on the cap, it's a $16 part, max.
Welcome to AZ, and G/L.
OP, just pop the cap off, and use the key.
Old Jul 6, 2010 | 10:24 PM
Ron A's Avatar
Administrator
Are you sure the keyfob is linked to the car.
Press and hold the lock and unlock buttons at the same time.
If it blinks once, you're linked. If it blinks twice, you're not, so do it again.
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
tman570
Jun 11, 2019 07:56 AM
nanos
Nov 12, 2015 08:41 PM
jordanboi
Sep 5, 2015 01:33 AM
