Keep having to fill power steering fluid
Old 08-03-2012 | 04:28 PM
itr1197's Avatar
I have an 04 TL. I started noticing a winding noise when I make turns. I checked the power steering fluid and it was very low, so I filled it up with honda/acura power steering fluid and the noise went away immediately. But now it comes back every few months and I keep having to refill the ps fluid. I never touched the fluid for 5 years and now I keep having to fill it every few months. What could be the issue?
Old 08-03-2012 | 05:42 PM
Turbonut's Avatar
A leak. Did you have the recall performed?
Old 08-03-2012 | 08:00 PM
blueracer17's Avatar
You have a leak, you need to find out where it is leaking and repair it. Have you looked at anything under the hood besides the PS fluid reservoir? Take a look at all the lines, the pump (especially the plastic return fitting off the pump-there is an o-ring in there that likes to flatten out and leak fluid.
Old 08-03-2012 | 09:18 PM
itr1197's Avatar
I didnt know there was a recall. Where can I find out more about this recall.
Old 08-03-2012 | 10:06 PM
DANELSON's Avatar
im have the same problem i checked underneath my car when it was on a lift and i spotted fuild coming from the power steering rack.I think it might be a seal or something.
Old 08-04-2012 | 05:51 AM
Turbonut's Avatar
Check the VIN to see if it's been done, if not:
Make: ACURA
Model: TL
Model Year: 2004
Manufacturer: HONDA (AMERICAN HONDA MOTOR CO.)
Mfr's Report Date: FEB 26, 2008
NHTSA CAMPAIGN ID Number: 08V091000
Component: STEERING:HYDRAULIC POWER ASSIST:HOSE, PIPING, AND CONNECTIONS
NHTSA Campaign ID Number:
08V091000
Summary:
HONDA IS RECALLING 273,000 MY 2004-2008 ACURA TL VEHICLES. PROLONGED HIGH UNDER-HOOD TEMPERATURES MAY CAUSE THE POWER STEERING HOSE TO DETERIORATE PREMATURELY CAUSING THE HOSE TO CRACK AND LEAK POWER STEERING FLUID.
Consequence:
POWER STEERING FLUID LEAKING ONTO A HOT CATALYTIC CONVERTER WILL GENERATE SMOKE AND POSSIBLY LEAD TO AN UNDER-HOOD FIRE.
Remedy:
DEALERS WILL INSTALL A NEW HEAT RESISTANT POWER STEERING HOSE FREE OF CHARGE. THE RECALL BEGAN ON APRIL 28, 2008. OWNERS MAY CONTACT ACURA AT 800-382-2238. THIS IS AN EXPANSION OF A PREVIOUS RECALL (PLEASE SEE 07V551).
Notes:
ACURA RECALL NO. Q73. CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV.
Old 08-04-2012 | 10:43 AM
nfnsquared's Avatar
OP,
There was another TSB before the recall to replace an O-ring. The recall also includes replacing this same O-ring. If it turns out that the recall was done, there is a chance that they did not replace the O-ring as required by the TSB. Several members had the recall performed and the dealer failed to replace the O-ring.
Old 08-08-2012 | 10:38 AM
05SSMTL's Avatar
I had the same issue. It whined under 50F and noticed a small amount coming out. Replaced the O-Ring (new one is Orange) and it completely fixed the problem. Try that- Cost like $.50. Quick fix- 5 minutes. Part number is 91345-RDA-A01
Old 08-08-2012 | 12:40 PM
ANTHONY741's Avatar
Steering Rack
I had the same issue around 75k. It needed a new steering rack. Dealer charged $1100 to replace
TL-Rocket
04-29-2023 02:33 AM
Yikes
05-03-2021 04:29 PM
mike from annapolis
05-07-2017 08:21 PM
fifer16
1G RL (1996-2004)
10-16-2015 08:54 AM
Quick Reply: Keep having to fill power steering fluid
