Just got off the flat bed!!
Old Aug 7, 2015 | 11:04 PM
sam617's Avatar
Wife was driving home from work tonight, saw smoke coming out the back off the car, next thing you know car just started to decelerate even when stepping on the gas pedal, she had to pull over call for a tow. Car is at home now, cel on nav screen for transmission p0767,p0796. Puddle of black oil that smells like burnt transmission fluid leaking from somewhere underneath the car. Do y'all think my transmission is done? Btw, car is a 2007 tls with 157k miles, one owner, just change the fluid about a month ago. Can it be leaking from a hose? Thanks, Sam
Old Aug 8, 2015 | 02:28 AM
YeuEmMaiMai's Avatar
most likely, yes the trans is done
Old Aug 8, 2015 | 12:16 PM
sam617's Avatar
Does anyone know how much fluid the transmission hold total? I know when you drain it, it only drain 3.5-4 quarts. Thanks, Sam
Old Aug 8, 2015 | 02:18 PM
truonghthe's Avatar
~ 9 quarts total.
Old Aug 8, 2015 | 05:51 PM
sam617's Avatar
I just finish checking the trans from underneath the car and it looks dry. The fluid leaked seem to be coming from around the top of the subframe area. Is there hoses connecting the transmission to the subframe area(front end) Thank, Sam
Old Aug 9, 2015 | 11:03 AM
sam617's Avatar
Found my problem!!! The bottom off the radiator(passenger side)where the elbow connection meet crack and let all the trans fluid leak out. Hopefully it's just the radiator I have to replace and not the transmission. Should I go to autozone or just get a oem radiator? Thanks, Sam
Old Aug 9, 2015 | 02:06 PM
ECRD's Avatar
So it was the fitting on the rad for the trans cooler lines? Very common.
Autozone, pep boys, etc have very poor quality radiators you will get what you pay for.
Another option is to eliminate the trans cooler lines going to the radiator completely and run a real external trans cooler mounted in the front of the car instead. Its cheaper, a nice trans cooler kit runs about $50-$75, its easy to install, better for the trans, and no need to replace the oem radiator.
This is what I did with both my mdx and TL's.
Old Aug 9, 2015 | 06:12 PM
sam617's Avatar
Are you speaking from experience with aftermarket radiator? Thanks, Sam
Old Aug 9, 2015 | 06:33 PM
csmeance's Avatar
Most auto parts are get what you pay for. Don't cheap out esp considering the wife is driving the car.
Did you try hooking up the lines without the cooler, and new fluid to see if the trans is okay?
Old Aug 10, 2015 | 11:07 AM
sam617's Avatar
I haven't tried hooking up the line to the trans cooler yet. Already place an order with delray for a radiator. Hopefully the transmission is still good.
Old Aug 10, 2015 | 11:41 AM
csmeance's Avatar
like buy a 3 foot hose, hose splices and you can connect it around the radiator (bypass it) to see if the trans is ok. Fill with the proper amount of fluid before starting.
Old Aug 10, 2015 | 02:09 PM
ECRD's Avatar
Yes I'm speaking from experience, Ive installed rads from those parts stores on multiple customers cars only to end up leaking due to quality, then having to remove it again, bring back for exchange, install again, who pays for double labor? Customer.
Buy oem quality once and done, will last up to 200k...
Yes you could just connect both trans cooler lines so it does not go into the rad and fill trans, clear codes, drive it to see it the trans is shot?
Old Aug 10, 2015 | 04:28 PM
sam617's Avatar
How much fluid should I put in? The dipstick read about1/8-1/4 of fluid. Thanks, Sam
Old Aug 10, 2015 | 05:24 PM
csmeance's Avatar
The entire trans holds about 9-10 quarts. The amount that'll drain from the drain bolt is 3.3-3.5 quarts. The dipstick should read between the 2 holes when the fluid is at operating temp, within 60 seconds of turning off the engine.It should be at the lower hole with the car cold at a minimum.
Old Aug 12, 2015 | 07:39 PM
mau108's Avatar
Had the same thing happen to my parents 07 RDX. Had to rebuild the transmission. If it got to the point the car was not accelerating any more then I'm guessing you are in the same predicament.
Old Aug 12, 2015 | 10:36 PM
polish_pat's Avatar
Is there really a transmission line close to the radiator? Seems odd.
Old Aug 12, 2015 | 11:06 PM
truonghthe's Avatar
07-08 TL has OEM external ATF cooler locate on the left front of the car. where 04-06 TL does not come with external cooler.
Old Aug 13, 2015 | 12:09 AM
polish_pat's Avatar
Ah! Explains why, I have 05 and just changed my motor mounts few days ago, I thought I was blind for a few seconds
Old Aug 13, 2015 | 03:43 AM
partially incorrect... part of the trans cooler is on top of the transmission with cooler lines going in and out...for the 04-06 cars
Old Aug 14, 2015 | 07:07 PM
sam617's Avatar
Update: Just finish replacing my radiator, added transmission fluid about 4 quarts and a gallon of radiator, started the car and she's moving now. Dodge a bullet, maybe? Idk, only time will tell?? Thanks for the help Acurazine!! Best forum ever!! Sam
Old Aug 14, 2015 | 11:03 PM
I hope it stays running but it has been my experience that once you run a Honda automatic dry while in operation, it will die a short time later...
Old Aug 15, 2015 | 09:28 PM
sam617's Avatar
Maybe the '07-08 trans is different? I just put 6 quarts of fluid in, the dipstick read about 1-2 over the top hole of the the dipstick(cold). I let the fan turned on(idling) and it still read the same. Did I overfill it? Is overfilling it going too cause problems? Should I let it sit over night and check the dipstick and drain and refill it again? Thanks, sam
Old Aug 16, 2015 | 11:02 PM
When you run the trans dry, the fluid is no longer there to cool things off and as a result the clutch packs and seals take a beating....
Old Aug 17, 2015 | 12:30 AM
LaCostaRacer's Avatar
Something similar happened to my Honda Pilot about 20,000 miles ago. My wife caught the issue in our driveway and the Pilot has been running well ever since. I installed the factory tow package that had a cooler but the radiator nipple corroded and we had the similar issue. At the time, our Pilot had about 80k miles so it seems like the Acura radiators might last a little longer possibly. I also thought the TL had a different design too so now I'll need to take a look for signs of a corroded nipple on my car and do a proactive replacement instead.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
calrow
May 3, 2017 10:21 PM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
