Just got off the flat bed!!
Wife was driving home from work tonight, saw smoke coming out the back off the car, next thing you know car just started to decelerate even when stepping on the gas pedal, she had to pull over call for a tow. Car is at home now, cel on nav screen for transmission p0767,p0796. Puddle of black oil that smells like burnt transmission fluid leaking from somewhere underneath the car. Do y'all think my transmission is done? Btw, car is a 2007 tls with 157k miles, one owner, just change the fluid about a month ago. Can it be leaking from a hose? Thanks, Sam
I just finish checking the trans from underneath the car and it looks dry. The fluid leaked seem to be coming from around the top of the subframe area. Is there hoses connecting the transmission to the subframe area(front end) Thank, Sam
Found my problem!!! The bottom off the radiator(passenger side)where the elbow connection meet crack and let all the trans fluid leak out. Hopefully it's just the radiator I have to replace and not the transmission. Should I go to autozone or just get a oem radiator? Thanks, Sam
So it was the fitting on the rad for the trans cooler lines? Very common.
Autozone, pep boys, etc have very poor quality radiators you will get what you pay for.
Another option is to eliminate the trans cooler lines going to the radiator completely and run a real external trans cooler mounted in the front of the car instead. Its cheaper, a nice trans cooler kit runs about $50-$75, its easy to install, better for the trans, and no need to replace the oem radiator.
This is what I did with both my mdx and TL's.
like buy a 3 foot hose, hose splices and you can connect it around the radiator (bypass it) to see if the trans is ok. Fill with the proper amount of fluid before starting.
Yes I'm speaking from experience, Ive installed rads from those parts stores on multiple customers cars only to end up leaking due to quality, then having to remove it again, bring back for exchange, install again, who pays for double labor? Customer.
Buy oem quality once and done, will last up to 200k...
Yes you could just connect both trans cooler lines so it does not go into the rad and fill trans, clear codes, drive it to see it the trans is shot?
The entire trans holds about 9-10 quarts. The amount that'll drain from the drain bolt is 3.3-3.5 quarts. The dipstick should read between the 2 holes when the fluid is at operating temp, within 60 seconds of turning off the engine.It should be at the lower hole with the car cold at a minimum.
Update: Just finish replacing my radiator, added transmission fluid about 4 quarts and a gallon of radiator, started the car and she's moving now. Dodge a bullet, maybe? Idk, only time will tell?? Thanks for the help Acurazine!! Best forum ever!! Sam
Maybe the '07-08 trans is different? I just put 6 quarts of fluid in, the dipstick read about 1-2 over the top hole of the the dipstick(cold). I let the fan turned on(idling) and it still read the same. Did I overfill it? Is overfilling it going too cause problems? Should I let it sit over night and check the dipstick and drain and refill it again? Thanks, sam
Something similar happened to my Honda Pilot about 20,000 miles ago. My wife caught the issue in our driveway and the Pilot has been running well ever since. I installed the factory tow package that had a cooler but the radiator nipple corroded and we had the similar issue. At the time, our Pilot had about 80k miles so it seems like the Acura radiators might last a little longer possibly. I also thought the TL had a different design too so now I'll need to take a look for signs of a corroded nipple on my car and do a proactive replacement instead.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
calrow
May 3, 2017 10:21 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
