Just crashed.......!!!!
Old Nov 21, 2009 | 11:34 PM
HarlemzFinest135's Avatar
Just crashed my 05 TL. My driver side airbag deployed. Can someone tell me what do I need to replace to fix this problem. Some people tell me I need a new module, airbag, and clock spring. Also where is the SRS module located.
Old Nov 22, 2009 | 02:30 AM
Phambam12's Avatar
Phmbm12
sorry bro
Old Nov 22, 2009 | 08:53 AM
arrogantbastard's Avatar
2008 Acura TL Type-S
Man, that sucks! Hope you're alright.
Anyway, I hope you're not thinking about replacing the airbag yourself. Take it to a body shop.
Old Nov 22, 2009 | 10:46 AM
07tl-s6spd's Avatar
Chapter Leader (Central New Jersey)
ouch....cant help you there...anyone?
Old Nov 22, 2009 | 01:21 PM
csmeance's Avatar
if your airbag went off, theres a bit more that needs to be replaced. What about the damage to your car?
Also does your seatbelt retract properly? There is a charge that locks it into place when the air-bags go off to keep you from moving too much. This whole mechanism needs to be replaced. Also why do you need a new module and clock spring?
Old Nov 22, 2009 | 02:45 PM
Yes thanks guys I'm fine. The body damage is minimal it's just the fender but for some reason it was enough for the airbag to go off. But a few people I have asked told me eventhough the airbag is replaced you still need to replace the srs airbag module or reset it.
Old Nov 22, 2009 | 08:07 PM
acuratech239's Avatar
Acura Cert MASTER TECH
csmeance is right to check your seat belt. To answer your other questions, yes, you will need a new airbag, and yes, you will need a new SRS unit. Assuming you're going through insurance, as the airbag and SRS unit aren't cheap. Glad you're ok though
