Just bought my TL, mirrors look like they have rust on them?
I disagree with unanimity
fries is right. the heated part basically burns through with age and causes discoloration. Need to replace the mirror. Since you just bought the car, I would see what you can get out of the dealer. What year is it?
There are a few threads about this. here's one....
https://acurazine.com/forums/3g-tl-2004-2008-93/2004-tl-driver-side-mirror-634000/
the same is happening to my driver's side mirror. I've been slacking on replacing it. I think some peeps just replaced the mirror, but if IIRC, they said it wasn't the easiest thing to do. (can't seem to find those threads).
Yeah bought my car the same.
Have to buy new glass =(
Wow, those are in bad shape.
I have the same problem on my driver's side. Just a little spot on the bottom. I may just live with it. Chances are it will happen again since I tend to forget to turn the heat buttom off.
ya those pics are exactly how mine look, thanks guys. i guess ill try to replace just the mirrors before i go out and spend a bunch of money on 07-08 full mirrors. and i didnt buy the car from a dealer it was a private seller so ill have to take care of it on my own. any tips on getting the old mirror off?
B A N N E D
edit: part # 5 and 10; about $36 each if picked up at the local dealer
https://www.hondapartsunlimited.com/...%20%28%2707%29
and i am not quite of what year you TL is, i see 05 in the name, but then you mention 07-08 ones, so i just selected an 07
That rust thing happened with 05 TL. Dealer replaced it free. The seal in the layers of the glass loosened up allowing water to get behind the glass causing that appearance...at least that's what they told me. They could have told me it was flying pigs and I would have been fine with that since they said they'd do it free.
guitarplayer16
11-29-2015 02:03 PM
sockr1
10-01-2015 01:31 AM
Trplezero
09-03-2015 10:25 PM
