Jumped cel after p2r spacer installed
Old Feb 13, 2009 | 04:51 PM
JwongTLS's Avatar
I just installed my p2r spacer and now i have a cel and the car keeps revving by itself to like 2500rpm?
I tried to reset the ecu but it still doesnt work? What should i do?!?!
Have this happened to anyone before??
Any help would be appreciated. Thanks!
Old Feb 13, 2009 | 05:00 PM
TylerT's Avatar
Turd Polisher
You need to reinstall, this happened to me as well.
I just shaved all of the original gasket, triple checked everything, and redid the installation and made sure there were NO air leaks.
Good luck.
Old Feb 13, 2009 | 05:04 PM
Bearcat94's Avatar
AZ Community Team
Vacuum leak.
The CEL is from disconnecting the IAT sensor while the battery was connected. It should go away on it's own in 20 or 30 miles.
Old Feb 13, 2009 | 06:07 PM
01tl4tl's Avatar
vac/air leak- whats too tight or too loose??
Any old gasket material will mess up the install as said above
Old Feb 13, 2009 | 06:39 PM
IBFStyles's Avatar
Most likely air leak from 2nd poster.
Old Feb 14, 2009 | 12:07 AM
JwongTLS's Avatar
Never mind...I found out what was the problem. I forgot to plug the spacer.
Thanks again! Take it easy
Old Feb 14, 2009 | 10:04 AM
01tl4tl's Avatar
Doh!
the ol forgot to install all the parts and tighten to spec trick~
Maybe seafoam caused the problem~
cycdaniel
Dec 17, 2019 10:58 AM
james357
Feb 13, 2016 02:37 PM
ryanfett
Oct 29, 2015 06:01 AM
NJALLDAY57
Oct 13, 2015 08:25 AM
obert
Sep 3, 2015 08:40 PM
