J32 problem?
Old Sep 27, 2018 | 06:02 AM
Humildes2212's Avatar
J32 problem?
I recently bought an 04 acura tl j32 base model...when I start the car it idles very rough and if I press the gas it shuts off...the hose thats connected to the intake from the rear head has to be disconnected otherwise it wont run and that same hose is blowing white smoke and leaking a little bit of oil mixed with antifreeze. Any ideads on what it could be? Im stumped my guess would be the rear headgasket is bad but its not mixing in the radiator or in the motor as I removed the cap only mixing through that hose ALSO ran the obd2 scanner and doesnt have any codes thanks in advance for any help
Old Sep 27, 2018 | 06:25 AM
horseshoez's Avatar
Latent car nut
Have a cylinder leak-down test performed; that'll tell you if you have a bad head gasket.
LOGONZOJLS
Sep 12, 2007 10:23 PM
cltypeSLOW
Dec 19, 2006 07:04 PM
r.j-lo
Oct 14, 2004 04:31 PM
r.j-lo
Oct 8, 2004 09:58 PM
