Its time for spark plug change
Old Jun 13, 2014 | 03:34 AM
E DOUBLES TL's Avatar
So i own a 07 TL type s and I'm at 92,000 the dealer suggest to change the spark plugs and adjust the valve. I have notice the engine sound a bit louder lately. I had spoke to another mechanic he also recommends to change the valve cover gaskets and intake plenum gaskets. So I was wondering if anyone where has done the spark plug change along with the other parts. Thanks for the help. If your located in the West LA area if you know of a good shop it will also help. I posted also in regions but so far no help
Old Jun 13, 2014 | 03:36 AM
YeuEmMaiMai's Avatar
only change stuff if it is leaking, otherwise leave it alone. You can change the plugs yourself for about $70. To change the valve cover gaskets involves removing the upper part of the intake manifold. Are you tube seals leaking? Are you seeping oil out from under the valve cover? IF not, leave it alone. Go to youtune and search for Eric the car guy and he will show you how to do a valve adjustment on a TL
Old Jun 13, 2014 | 05:43 AM
nfnsquared's Avatar
OP, if the "loudness" is a ticking sound, stop now and check your plugs for a loose plug.
Old Jun 13, 2014 | 06:07 AM
Adobeman's Avatar
The DVD-A Script Guy
op, if the "loudness" is a ticking sound, stop now and check your plugs for a loose plug.
+1
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
PortlandRL
Sep 14, 2015 12:01 PM
NSolace
Sep 3, 2015 08:14 PM
