Its that normal??
Its that normal??
As you are going to see in the picture below, i noticed this Switch and this cable like a sensor in driver's place inside the car in the left corner above the fuse box... Its normal to have those switch and this like-sensor cable overthere? Or what it can be? Because i have the factory Alarm and everything seems to works fine
As i have mentioned before in some post and with no answer, i still not able to open the trunk from the bottom inside of the car, but i noticed that the bottom seems like its doesnt have the cable connected or its that supposed to look like that?? See picture below to noticed the connector without any cable connected, Its the black one with the purple thing around
Dude, those are your nitrous arming and activation switches. All TLs came with a 50 shot from the factory. You can upgrade to a 75 or 100 shot before you blow the welds on your intake.
But really...is it a DIY ignition kill switch?
it could be any kind of switch.
light switch, dvd switch, absolutely anything the previous owner did to the car.
unless there is evidence that the previous owner left to clue you in.
and im not following you on the trunk switch.
ask again, and or re-phrase the question
Exactly man is that switch, the only one u have inside to open the trunk, i already checked the glove box switch and it was unlocked, and still the same issue! but as i show in the picture, i believe that it should be something connected in that switch! What u think?
MrHeeltoe
20
Feb 23, 2023 01:54 PM
rockyboy
Oct 2, 2015 10:45 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
