Issues after 3rd/4th switches were replaced
Old 09-04-2012, 11:13 PM
5th Gear
cnjsommers's Avatar
First of all thank you all for the great DIYs and research. I have found very valuable information that has saved me some cash.
My Problem:
I was having issues with the car going into limp mode. The check engine light VSA light and triangle with exclamation point would come on and the car would not accelerate. I found on other posts to change the accelerator pedal sensor assy and that seemed to fix the problem right away. YAY
a week later I noticed my transmission seemed to be acting up. The shift into 3rd gear was fluttering and was not feeling correct. Saved by the forum once again I was told to change the 3rd and 4th switches. Worked like a dream for 1 day, thanks to a great photographic DIY posted on here. I also got the parts listed on this DIY from the Acura dealership.
Now I have the same issue as before with all three lights on and the accelerator not really working. Any ideas?
I just re-installed the old 3rd/4th switches and just for good measure will let it sit overnight with the battery disconnected. hopefully this will fix the limp mode issue but I am back to square one with the transmission flutter going from 2nd to 3rd. I have not yet had the transmission fluid changed but will do tomorrow.
I just had a very well trusted independent imports shop change my timing belt and everything that normally goes with that as my millage is at 126000 so ya sorry I was late getting it done. The check engine lite was on when I took it in so I thought why not have them do a diagnostic. They came up with code P2770- Torque Converter lock up. They tested the solenoid five different times and found it to work fine.
Any help would be GREAT!
Old 09-05-2012, 01:00 AM
mindanaomoro's Avatar
Is that the original tranny? What yr is your car? Try changing ATF to Type F, and see how it'll work, but with that TC code your tranny might be due for a rebuild.
cnjsommers (09-05-2012)
Old 09-05-2012, 02:31 AM
roof2006's Avatar
I suspect that you have a couple of independent problems going on here. I had the "lights on and limp mode" problem, and it was my app sensor.
Old 09-05-2012, 01:33 PM
5th Gear
cnjsommers's Avatar
I did change the app sensor already as noted in the original post. Yes it is also the original trans for the car.
Old 09-05-2012, 01:37 PM
roof2006's Avatar
Didn't know that accelerator sensor = app sensor. (My mechanic didn't know what it was, either.) The other thing we tried was the throttle body - but you're not getting that code.
Old 09-05-2012, 01:47 PM
5th Gear
cnjsommers's Avatar
Also It's a 2004 TL 3.2L
Old 09-08-2012, 09:11 PM
5th Gear
cnjsommers's Avatar
Update---
I put the old 3th and 4th switches back in and two days later the D light is blinking the check engine light is on as well as the VSA and triangle exclamation point. Help
Old 09-09-2012, 12:13 AM
anionrings's Avatar
when my 2nd gen TL transmission gave out...it was doing the same thing...but thats 2nd gen...
Blinking D light of Death with VSA and TRIANGLE light on the whole time...
but i hope thats not the case
Old 09-09-2012, 02:46 PM
Yeah man being 2004 original tranny @126K miles that's a high probability that tranny is going dead.
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
orkoTL
4G TL Problems & Fixes
107
09-28-2017 09:12 AM
Skirmich
09-15-2015 06:41 PM
NSolace
09-03-2015 08:14 PM
Quick Reply: Issues after 3rd/4th switches were replaced
