Intermittent starting problem
Old Apr 26, 2009 | 10:51 PM
Kandyman's Avatar
Twice this week, my car has failed to start. No turnover, no click. Just dead silence. Moving key to start position instead killed all electrical power.
First time, I had left the headlights auto-shut off the night before. In the morning, I unlocked with the remote, headlights came on bright. I got in and turned on the radio while waiting for my kids to buckle up. When I moved the key to the start position, everything went dead. There was no cranking or clicking. All internal lights went dead. I opened the hood and checked battery connections. They were tight. Went back into the car and tried again, and it started immediately.
A few days later, the same thing happened again. I unlocked with the remote, got in and turned the key and accessories all came on fine, then turned to start and everything went dead. I was in a rush this time so I just took my wifes car. Came back home about 3 hours later and tried my car again. It started immediately.
Battery terminal connections are tight. Battery is less than 2 years old, and there are no problems with cranking - when there is power. Could this be a loose connection in the fuse box? Any suggestions? Thanks!
Old Apr 27, 2009 | 06:21 AM
blkaspec's Avatar
Full of water...
I have killed two batteries in the two years i have owned my car, and one was an expensive Braille battery. Go to the dealership and have them check it out. They will more than likely replace it if it is dead.
Old Apr 27, 2009 | 11:41 AM
Majofo's Avatar
+1.. but I'd rather have them give me cash back and buy a decent aftermarket battery. Get at least $100 on it..
Old Apr 27, 2009 | 02:58 PM
csmeance's Avatar
have them check the ignition switch
Old May 17, 2009 | 07:38 AM
specter116's Avatar
7th Gear
i have the same problem but my accessories stay on...so when i turn the key to start it cranks once then it stops. if i hold the key in the start position it will crank and stop several times before the car starts.
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
obert
Dec 14, 2015 11:36 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
