Intermittent noise from starter
Old Aug 30, 2016 | 07:18 PM
Confusednewb's Avatar
6th Gear
Every few starts, My starter, or at least I am fairly sure thats what it is, makes an aweful squeeling noise and will stay that way until the car is restarted.
I have recently found out that if I turn the key all the way forward to start while the car is still running, the noise wil stop.
A more mechanically inclined person told me earlier thatche thinks that the starter is staying engaged. He said it could either be the starter itself, or the ignition switch that is the problem.
Should I be trying to replace the starter, or would this problem maybe lie in the ignition switch, or. Maybe somewhere else?
Thanks all!
Old Aug 30, 2016 | 09:02 PM
Yes sounds like that starter pinion gear is sticking . Replace it with an Denso one. (OEM manufacturer )
Old Aug 31, 2016 | 09:06 AM
6th Gear
Thanks!
Bought an ultima from Oreileys but havent touched it yet so will prob take it back. Ill try to find an OEM
Old Aug 31, 2016 | 09:33 AM
nfnsquared's Avatar
If Denso is OEM for the starter, that's news to me. Denso makes the OEM compressor, but not the starter AFAIK. I believe the OEM starter is made by Mitsubishi....
Go to RockAuto and order the Mitsubishi made aftermarket starter for only ~$120.
Old Aug 31, 2016 | 09:34 AM
Whoops! you may be right on that one
my bad!
Old Sep 6, 2016 | 05:34 PM
6th Gear
Problem soved
It was the starter after all. Replaced it and is starting up nuce and strong.
PITA TL
Jan 10, 2017 10:03 PM
RCpilot
Aug 1, 2016 09:32 AM
lojik
Jul 4, 2016 07:01 PM
Wheels KeepTurning
1G TL (1996-1998)
Apr 27, 2016 08:39 PM
3pol6
2G TSX Problems & Fixes
Apr 14, 2016 08:13 PM
