Interior Steering Wheel Lights (Audio and Cruise Modules)
Old Sep 26, 2012 | 08:08 AM
user 08723908028024's Avatar
Hello, everyone:
I need help with the below threat (G-100: DIY LED Interior Part III: Steering Wheel LEDs (Audio and Cruise Modules)
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-part-iii-steering-wheel-leds-audio-cruise-modules-763640/
I am stuck on picture #5 - I tried to use the torx (T-30) to drive the two bolts out, but unscucessful! It is too tight, and was unable to unscrew it.
Would someone help?
Thank you in advance! And drive safely!
Old Sep 26, 2012 | 08:11 AM
SharksBreath's Avatar
BANNED
does your t-30 bit fit in the opening securely? is your bolt stripped? are you sure you have a t-30? is it long enough to get a good fit in the hole? (giggidy)
t-30 is what i used and it worked fine for me. what sort of problem are you running into? need more leverage?
Old Sep 26, 2012 | 10:19 AM
@sharksbreath
Yes, the T30 fits and is long enough to fit. I also tried to unscrew the right sided one, and was also unable to loosen the tight screw.
I just need to replace the lights as they are all burnt out. Cruise control, Mode, Volume, Channel, etc.
Thank you!
Old Sep 27, 2012 | 11:36 PM
mzilvar's Avatar
I took my airbag out when I wrapped the switch bezels with DI-NOC.
One of my sides came out easy, with the other I had to line up the T30 bit and tap it in with a hammer it was just slipping otherwise when I tried to take it out.
After tapping it in it unscrewed easily.
Old Sep 28, 2012 | 07:49 AM
Oh okay! Thank you,@mzilvar -- I will definitely try this!
Old Sep 30, 2012 | 09:22 PM
quanaman's Avatar
TL-S
Be really careful.
One of mine is stripped. Therefore I'm stuck with an ugly steering wheel and completely burned out bulbs essentially forever.
Old Oct 3, 2012 | 12:58 PM
cipdagr3at's Avatar
HASTA LA VICTORIA'
Good luck, I had the toughest time with those. Ended up drilling through it just to get them off... for some reason it was installed with heated thread lock..
Feb 25, 2020 09:57 AM
james357
Feb 13, 2016 02:37 PM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
MyKids&Cars
Sep 2, 2015 12:03 AM
