Interior lights randomly come on
Old Sep 15, 2009 | 09:00 AM
Dave88712's Avatar
Has anyone had there interior lights randomly come on while driving and a chime go off? I hear a small chime and the dome lights come on for like 3 seconds then go away. I dont see any lights on dash that say what the problem would be. Any ideas? thanks
Old Sep 15, 2009 | 09:21 AM
LoveMyTL-S's Avatar
Hmmmm, weird. Almost sounds like a door was left slightly open.
Old Sep 15, 2009 | 11:25 AM
Dave88712's Avatar
Thats what i thought but all doors were closed. i thought it might be some kind of safety thing for wheelspin or something to alert the driver.
Old Sep 15, 2009 | 07:40 PM
shftl's Avatar
Bad door switch?
If you're sure all the doors were closed tight it is most likely a fault in the pin switch in one of the doors. This used to be a fairly common problem in American cars. Do you also get the open door icon on the MID? I'd bet you do, and if you can catch a good look at the icon it will tell you which door has the bad switch.
Old Sep 15, 2009 | 09:04 PM
TLin401's Avatar
'13 Hyundai Sonata
Def a short or something in one of the door sensors.
Old Sep 16, 2009 | 02:05 AM
Bearcat94's Avatar
AZ Community Team
Old Sep 16, 2009 | 12:02 PM
Dave88712's Avatar
Ya it happens pretty rarely but when it does its so quick so by the time i look at the MID its already gone. Im guessing your right about door switch though.
Old Sep 16, 2009 | 07:01 PM
ozzfest's Avatar
'07 ASM TL NAV
We had a similar issue. But, with ours, the door looks would also unlock and then lock. Had a bad negative cable on the battery. Replaced the battery and cable. Now all is fine.
Old Sep 16, 2009 | 07:37 PM
acuratech239's Avatar
Acura Cert MASTER TECH
Dave -
A quick way to check, and this is one of the ways we do it at work, is to first put all the windows down, then (with the car running), lock all the doors. Then go around from door to door and pull, either on the door (at the bottom of the window), or on the handle, though I don't recommend the handle. You're pulling on the doors to simulate them opening a little around a turn/bump, causing the door switch to indicate "open door". Reason for having the car running is because you'll set the alarm off otherwise (locking it with the key out, etc); that's just annoying, but moreso because you'll be able to get audio confirmation (the door chime/warning) as well as visual (the MID indicating a door open).
Find the problem switch; it may not be bad, just may need adjusting. If no door acts up, you can try the trunk, although it's very rare for the latch to go bad (in that sense; we see them just flat out fail to open usually).
Good luck!
Old Sep 28, 2009 | 08:57 AM
Dave88712's Avatar
Thanks guy i realized that is my passenger side door switch. how would i adjust it or replace it?
Old Sep 28, 2009 | 06:47 PM
shftl's Avatar
Well, a new one is $3.44 plus shipping:
http://www.acuraoemparts.com/delray/...All&vinsrch=no
As someone said, they sometimes need some adjustment. The door is supposed to push the plunger in far enough to break the circuit. I'd mess with it, pull it out, see if it seems to function correctly on its own, in which case it presumably needs a mounting adjustment. If you can push the plunger in all the way and still make the interior lights come on by some means--position, rotation, pulling (gently) on the wire lead, etc.--it probably needs to be replaced. I believe you will have to keep the metal part of the switch in contact with the car body for the interior lights to come on.
Feb 25, 2020 09:57 AM
handsom-hustla
Nov 13, 2015 05:04 PM
sockr1
Oct 1, 2015 01:31 AM
PortlandRL
Sep 14, 2015 12:01 PM
oyayjoe
Sep 12, 2015 04:40 PM
