Interior light problem
Old Nov 29, 2011 | 02:06 AM
erzhan89's Avatar
Today, I noticed that my lights do not turn off when I close doors and start engine.
To turn off I have to switch button to OFF(left side). On the middle position (doors open) of button, lights is working.
What might happen ?
it's happening first time for me.
THanks,
Old Nov 29, 2011 | 08:28 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
Are all of the lights staying on or just one or two?
You may want to double check and make sure you or someone didn't turn on one of the lights manually - by pushing it up toward ceiling (toggle).
Old Nov 29, 2011 | 10:03 PM
erzhan89's Avatar
all of them: front and rear.
I suspect a fuse.
Is there any list or diagram of fuse box ?
Old Dec 1, 2011 | 03:18 PM
NBP04TL4ME's Avatar
Do the lights turn off when you park the car, close the door and lock the doors? It almost sounds like there is a break in the circuit somewhere or one of your door pin switches isn't working properly. In other words the lights stay on, because "a door is open."
In terms of the fuse box listing - it's in your owners manual and at least for the fuse box under the hood, it's under the cover.
Old Dec 1, 2011 | 11:44 PM
erzhan89's Avatar
If door was open, I should get message on central display. But, it doesnot.
Old Dec 2, 2011 | 09:21 AM
jokerman826's Avatar
Jokerman
Most likely the switch is messed up. I know on mine, I have the oposite. The lights do not like to turn on and I have to tap the on-auto-off switch for it to work. So most likely the switch is your problem.
Old Dec 2, 2011 | 10:28 AM
erzhan89's Avatar
Hey guys, Problem was solved. Issue was with fuse. I changed fuse 7.5A.
Thread can be closed.
Old Dec 2, 2011 | 07:19 PM
NBP04TL4ME's Avatar
Nice What's better than an easy fix? Although, admittedly I'm surprised this fixed it.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
handsom-hustla
Nov 13, 2015 05:04 PM
PortlandRL
Sep 14, 2015 12:01 PM
HeloDown
Sep 8, 2015 06:51 PM
