Interior Light Blinks and Beeps On Sharp Turns
Old Dec 23, 2007 | 01:25 AM
Select_TL's Avatar
Ka-Chow
I have a 2007 TL and when I make a sharp turn or hard turn the front console lights blink 2-3 times. Has anyone else have this problem?
Thanks!
Old Dec 25, 2007 | 06:13 PM
Select_TL's Avatar
Ka-Chow
Old Dec 25, 2007 | 11:32 PM
timmahh's Avatar
it's me, Alan Rickman.
front console light... ?
like.. the VSA triangle to indicate you're cornering sharp and getting some wheel slippage?
which light =/
Old Dec 25, 2007 | 11:42 PM
tl_dinhsum84's Avatar
Vsa Is Probably What It Is
Old Dec 26, 2007 | 01:17 AM
Bearcat94's Avatar
AZ Community Team
That's what I'd think.
BUT if he means backlights or ambient lights, then it is not normal and is probably a loose connection somewhere that the dealer would fix under warranty.
Old Dec 27, 2007 | 05:37 PM
Select_TL's Avatar
Ka-Chow
Actually to make it clear... it's the DOME light and no VSA. It also beeps like the door is open on sharp curve or turns.
Old Dec 27, 2007 | 05:47 PM
timmahh's Avatar
oh... well then possibly a bad door switch; could be shorting out or may not be tight and it might be completing the circuit so the car thinks the door is ajar..
do you notice if it happens when you turn to the left or right ?
Old Dec 27, 2007 | 06:21 PM
elkayem's Avatar
I have posted about this a while ago too, someone told me to check the fuses.
I checked, fuses are fine. And I have recently found out which door it was. (front passenger door)
Not only on sharp turns, if I nudge the door alittle from the inside, with the door closed, it interior dome light comes on and dash beeps too.
Old Dec 27, 2007 | 09:05 PM
csmeance's Avatar
theres a little sensor in the door jamb that may be bend. It sticks out about an inch and has a ribbed black plastic covering on it. Open the door and push it, the door open light should go off. If it is not making proper contact or is bent, it will set off the lights.
Old Jan 21, 2008 | 08:16 PM
Jimfred's Avatar
I have the same problem. Acura has made two attempts to fix it, both unsuccessful. I my case it is the front passenger door sensor (I get the impression that it is something like a Hall sensor).
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
redsox68
Sep 16, 2015 06:18 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
