Intake manifold gasket upside down?
Old Jan 22, 2018 | 10:19 PM
BigKillerDFW's Avatar
I've seen some threads talking about how the intake manifold gaskets can be put on upside down although I'm not sure if it applies to our 3G TLs. Does it matter which way is up on the factory gaskets? If so, is there a way to tell which way is up? I took mine out and am not sure which way was up (yeah, yeah) so am a little paranoid about putting it back together. I don't see any clear markings on the gaskets.
Old Jan 23, 2018 | 11:12 AM
svtmedic's Avatar
I don't believe they are marked which way up/down. Put mine back on the way it was on. They are metal. So you should be able to re use it. If your paranoid buy a new gasket. As long as We are talking intake plenum.
Old Jan 23, 2018 | 02:02 PM
Yeah, it's the intake plenum. I just didn't know orientation would be a potential problem.
Old Jan 23, 2018 | 02:37 PM
svtmedic's Avatar
Orientation should not be a problem. And when work is done that requires those sorts of things to come off I always take pictures that way I know what I'm dealing with. But no to answer your question orientation should not be a problem
Old Jan 23, 2018 | 02:40 PM
svtmedic's Avatar
Orientation should not be a problem. And when work is done that requires those sorts of things to come off I always take pictures that way I know what I'm dealing with. But no to answer your question orientation should not be a problem. when you put it back together if you get a vacuum leak or have a vacuum really you'll know it because the car won't run well, given it's no fun to do the job twice. Never hurts to ask though.
Old Jan 23, 2018 | 02:42 PM
svtmedic's Avatar
I hate when things post twice don't know how that happened
01CLinprocess
Jan 14, 2017 04:00 PM
Nitin
Jul 28, 2014 10:35 PM
shibalyeun
Apr 22, 2012 02:16 PM
deadlyklappy12887
Apr 26, 2010 07:26 PM
NSXNEXT
May 15, 2004 09:53 PM
