Intake Manifold Cover Bolts
Old 03-04-2009 | 09:02 PM
Bearcat94's Avatar
AZ Community Team
I discovered this evening that I am missing an Intake Manifold Cover bolt. Where it went or when, I don't know.
Turns out ALL the Cover bolts were loose. I had the cover off once, over a year ago, and installed the bolts per the Service Manual (tightening order and torque spec).
Should I use a dab of Locktite Blue Threadlocker to keep 'em in place?
Old 03-05-2009 | 07:55 AM
Bearcat94's Avatar
AZ Community Team
Bump
Old 03-05-2009 | 08:05 AM
01tl4tl's Avatar
normally you go back in 500 miles and retighten any intake or exhaust bolts after working on them
A few heat cycles tends to loosen a few or more~
Loctite would be personal choice- once its on the toque is set- so it better be right
Old 03-05-2009 | 08:06 AM
01tl4tl's Avatar
by the time to get ready for track day by checking the car over and finding things like this,,the car should run wayyyy better!
Old 03-09-2009 | 06:25 PM
Bearcat94's Avatar
AZ Community Team
Can you believe I lost another one of these GD bolts?
After discovering the first one missing and all the rest loose. I replaced the one and tightened all the others.
Couple of days later, checked 'em all - still tight.
Then yesterday, one is missing.
WTF??
Old 03-09-2009 | 08:00 PM
I hate cars's Avatar
That's weird. Any chance they're bottoming in the holes and not clamping down on the manfold completely?
What type of gasket/did you reuse the old one? Any polishing done to the manifold?
A dab of blue won't hurt anything but all you need is just a single drop.
Old 03-09-2009 | 08:18 PM
Bearcat94's Avatar
AZ Community Team
I don't think they are bottoming out. They call for pretty light torque, ~9 ft/lbs, just beyond hand tight. I know I could wrench them down more, so they are not bottomed out. And they are not over tight either - hand tight, then just a little pull with the wrench.
Last year, when I changed the Intake Manifold Gasket, I re-used the cover gasket.
No polish - just the stock cover. I am going to go through and put some Locktite Blue on them. One of those bolts get's tossed into a spinning part (fan blade, belt, etc) and I don't think it'll be a good thing.
cycdaniel
12-17-2019 10:58 AM
james357
02-13-2016 02:37 PM
kmarqueling
10-03-2015 01:14 AM
HOWELLiNC
09-18-2015 11:12 PM
EvilVirus
08-31-2015 05:24 PM
Quick Reply: Intake Manifold Cover Bolts
