Innovative Mounts Side Bracket Gap Issue
Old Jul 20, 2024 | 07:48 PM
ALEX420CLARK3's Avatar
Alex.UA6
Hello all,
I’ve had my innovative motor mount set in for about 10 years now. There has always been this 1” gap between the side bracket and side mount. I had my mechanic do the install and afterwards he informed me that my motor had risen about an inch. In turn, he ended up putting spacers in between to fill gap.
I took a closer look at everything yesterday and everything is bolted down correctly. There’s no loose bolts or any bent parts. There is obviously no issue with the bushings as it’s been like this since day one.
i’m very curious if anybody else has had this issue or can you tell me why my motor is sitting higher? Feel free to reply to me here or send me a DM on Instagram @alex.ua6.
Old Jul 20, 2024 | 09:39 PM
Interesting, just an FYI, the guy below had similar fitment issues with aftermarket mounts back in the day, on his 2G TL-S build with xlr8 mounts, then he switched to innovative.
The quote below is numbered post 24 on his thread.
02 TL-S 6MT Build - AcuraZine - Acura Enthusiast Community
Originally Posted by UA5_6MT
I had the xlr8 75a mounts for probably 6yrs or so. I removed them from the accord to use in the TL. I had the mounts powdercoated and new 75a inserts made. We were having fitment issues with the xlr8 mounts in the tl, come to find out the 02-03 tl rear mount is taller. So i picked up some innovative 75a mounts to use. The innovative mounts fit alot better but still needed some spacers
Motor bolted down on the xlr8 mounts front, rear and passenger side.
Xlr8 and innovative mounts
Innovative rear mount
Innovative front mount
Passenger side innovative mount spaced with some temporary washers
Motor sitting straighter and not crooked mounted
3/4" spacers might need to go taller on the passenger side.
Spacers mounted
to make some spacers for passenger mount and trans mounts.
Old Jul 20, 2024 | 09:47 PM
Alex.UA6
yes, this is also very strange. I appreciate you sharing it with me.
Spankz-
ILX
Jan 18, 2024 01:45 AM
Glorygang600
Jun 17, 2017 06:01 AM
AMart83
Sep 11, 2014 07:28 PM
cincinattlguy19
Nov 21, 2013 07:40 PM
nicotls
Jan 9, 2011 12:30 AM
