Injectors making noise
Old Oct 11, 2008 | 05:25 AM
UplandTLsleeping's Avatar
Addicted to Speed
Let's hope this questions goes over better than the last. For some time now, I've heard a loud pumping noise coming from the engine. I began to wrote it off as my injectors are abnormally loud.
But, in good spirit and great faith I'm putting the ? to u all. Is it possible my fuel injectors are working loudly?
Old Oct 11, 2008 | 01:46 PM
csmeance's Avatar
since when has this been happening? Since the Dry NOS setup?
Old Oct 11, 2008 | 02:15 PM
I hate cars's Avatar
Exactly.
I sincerely hope it's not a big problem but I could pretty much guarantee you your injectors are not the problem.
Check your oil to make sure it's still oil colored and not milky.
Check the exhaust for excess steam or water.
You probably popped a headgasket. I did 7 headgasekts in my learning process so don't feel too bad.
Still running a 5-20 oil with nitrous? You need a good 10-30 or even a 15-40 depending on your climate for the loads encountered with nitrous.
When running a completely new setup it's always a good idea to run some unleaded racegas while you get the bugs worked out to give you extra screw up room.
Any more details on the noise? Does it change with rpms? Does it get louder with throttle or is it purely rpm based? What if you manually hold it in gear at 3,500rpm and let off the gas, does the sound disappear? Is it more of a tick or a knock?
Old Oct 19, 2008 | 05:10 PM
RACINGHART03's Avatar
Inectors are small electronic solonoids. The only noise you would hear is a "clicking". You described your noise as a "pumping". Pull out your dipstick and see if the noise changes.
Old Oct 19, 2008 | 08:02 PM
csmeance's Avatar
also what other stuff have you changed from factory parts?
Old Oct 25, 2008 | 03:32 AM
Addicted to Speed
Check your oil to make sure it's still oil colored and not milky. Oil good
exhaust good
Still running a 5-20 oil with nitrous? 10 30
gas: 100 octane or 103 depending on day
My dry NOS is changed to direct port/////////CSMENCE
Old Oct 25, 2008 | 10:08 AM
01tl4tl's Avatar
just for fun- listen to the ac belt tensioner pulley- if still installed~
its gone bad on more than 1 TL and makes a really bad noise, almost valve like- but with a garage band sound when using a mechanics stethascope
Feb 25, 2020 09:57 AM
2012wagon
Sep 29, 2015 04:21 PM
Gary Matthews
2G CL Problems & Fixes
Sep 11, 2015 01:21 PM
Mike Bertram
Sep 10, 2015 09:27 AM
NSolace
Sep 3, 2015 08:14 PM
