Ijdm DRL's stopped working
Old Feb 15, 2013 | 04:41 PM
Gjboor89's Avatar
Took my from end to replace hids when I installed everything back the drls won't turn on anymore I have the ijdm harness with resistors. The fuse in there harness is still good. Any clues?
Old Feb 19, 2013 | 11:24 PM
LoveMyTL-S's Avatar
Check the fuse under the dash. I'm not sure which one but look at the inside cover to see which fuse is for your DRL's.
Old Feb 20, 2013 | 01:49 PM
michaelw21's Avatar
DRL fuse under the dash is #3 on the bottom row.
Old Feb 20, 2013 | 04:30 PM
paperboy42190's Avatar
so many possibilities...
Old Feb 20, 2013 | 04:51 PM
The Machine's Avatar
Registered Member
Let me translate here. You took your front end of (bumper) to replace the HID's? Is that what you're saying?
If you took any of the wiring apart from the DRL kit, maybe you reconnected it wrong? The most crucial part of the install is making sure the red wire is in line with the black wire. If this is reversed the lights will not work.
SilverJ
1/2G MDX (2001-2013)
Sep 21, 2015 02:40 PM
acurajj
Sep 19, 2015 03:47 PM
theinsvnity
Sep 10, 2015 10:22 PM
spiel08
Sep 7, 2015 08:19 PM
Fadij
Sep 2, 2015 08:31 PM
