Ignition
Old May 18, 2009 | 05:22 PM
pekkieboyz's Avatar
Ignition
I notice now when I start the car, the engine cranks at least three times before the engine start. Is this normal?
I know that during the winter it may take a while, but since it’s spring and the weather around nyc is at an mild cool/warm setting, I don’t think the weather plays a factor.
I also checked the battery to make sure it’s alright and everything fine. I’m just not to sure if it’s a engine problem now.
How long does it take for your engine to start?
Old May 19, 2009 | 07:22 AM
LoveMyTL-S's Avatar
Mine starts right up. Are you still on the OEM battery? If so, it may be weak.
Old May 19, 2009 | 09:59 AM
01tl4tl's Avatar
how did you test the battery?
by having a parts store or shop do a complete voltage at running rpm, load test and starter draw-recovery?
Its free at most major parts stores
Acura batteries are lucky to last 3 maybe 4 years
How many miles- you could be due for an intake cleaning, some gas claner or new spark plugs
But really test the battery first
Old May 19, 2009 | 09:40 PM
pekkieboyz's Avatar
I actually went to the dealership and asked to them check it out, and they say everything is fine, and the battery is fine.
TL-06- 25k mile on it..
maybe it's time to change the battery and some new spark plugs
Old May 19, 2009 | 10:09 PM
I hate cars's Avatar
It's hard to say without hearing it. I've heard the TL's engine is supposed to make 2-3 complete rotations on the starter before it fires. Supposedly so that it builds some oil pressure before combustion.
I remember reading that the McLaren F1's BMW engine did the same thing for the same reason.
Mine turns over plenty fast but it definately takes a little longer to fire than most of the other cars I've owned.
Old May 19, 2009 | 10:25 PM
NAiL05's Avatar
I think it was stated in the manual when the engine is hot it takes a lil while longer to start the car. I havent had much issue with mind it starts most of the time...But I think it has to do with the emissions deal. I remember reading it on the thread a while back. I found it kinda odd.
Acura604
20
Aug 5, 2017 12:55 AM
ExcelerateRep
Oct 14, 2015 08:20 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
malvothegreat
Sep 29, 2015 12:38 AM
h22lude
Sep 27, 2015 06:22 PM
