Idle issues after installing HO Alternator
Old Nov 1, 2023 | 11:56 AM
OnlyDaanish's Avatar
Hi Everyone,
So, A while back I changed my stock alternator to a High output alternator from Michael Singer. https://www.singeralternators.com
Ever since then I noticed my TL can never idle properly. This is mainly noticeable if I Break a bit hard when I come to a stop, or when I turn on/off the AC. there is a sudden surge in my idle dropping to 600 then back up to 750 like its choking for a second.
I noticed this alternator outputs 14.8V constantly and I think has an ELD bypass built in and perhaps the ECU is trying to lover the voltage and dropping idle?
Old Nov 1, 2023 | 09:54 PM
csmeance's Avatar
did you ever do the idle relearn procedure?
Old Nov 1, 2023 | 09:55 PM
yes several times. I’m also assuming the idle relearn occurs when battery is disconnected
My procedure was. i turned the car on and kept it at 3000 rpm until the radiator fan comes on. Then wait 10 mins at idle and then the car off.
LeVeL
Sep 10, 2018 12:04 PM
Brandon Allen
Jul 6, 2015 09:14 AM
Acura2g
Apr 27, 2009 03:48 PM
lostchild83
Oct 5, 2006 11:02 AM
