I-166: Weak signal range keyless entry....
Old Feb 27, 2009 | 01:33 PM
timb24's Avatar
once you go black....
Hey guys I've done a search on this topic with limited success so I thought I'd get your advice.
My signal range on my keyless entry is absoultly pathetic. I have to be within at least 10 feet of the car and sometimes it still doesnt work. There are occasions where im standing right next to the car and have to press it like 5 or 6 times to get a response. It's very frustrating..
Could this be because of a weak battery? or are there other issues that I don't know about. Thanks...
Old Feb 27, 2009 | 02:17 PM
anarchy[sear]'s Avatar
KICKED IN THE BALLS
Put the remote underneath your chin and say ahhhhhhhhh and press the button. It will work from further away ;p
Old Feb 27, 2009 | 02:21 PM
timb24's Avatar
Yea ive tried that, but still its very inconsistent, even at very close range.
Old Feb 27, 2009 | 02:30 PM
KICKED IN THE BALLS
HAHAHAhaha Try replacing the battery mine does it once in a while too. Its inconsistent.
Old Feb 27, 2009 | 02:42 PM
timb24's Avatar
Does anybody know what kind of battery I need to get?
Old Feb 27, 2009 | 03:14 PM
djbonsu's Avatar
"Like None Other"
the remote fobs just plain ol' SUCK!! i replaced my battery twice and the range is still the same....SUPA WACK
Old Feb 27, 2009 | 04:34 PM
csmeance's Avatar
I think its a regular watch battery. open it up and see the battery model number to be sure.
Old Feb 27, 2009 | 04:37 PM
Will Y.'s Avatar
Registered but harmless
The manual says CR2025 batteries: https://techinfo.honda.com/rjanisis/...505O00093A.pdf
Old Feb 28, 2009 | 01:35 PM
hirsch014's Avatar
agreed, they suck. once in a while i have to stand by my car and keep trying till it locks before i can walk away. then other times, i'll see the lights turn on thru the apartment window 50 yards away if i hit the button in my pocket.
it often acts like the battery is weak, but changing it doesnt help. makes the roll-down window feature worthless.
oh, and you can get the battery at any walmart, just bring a little screw driver with you and pop it open in the store to match the numbers.
Old Feb 28, 2009 | 01:51 PM
Babnik's Avatar
My range used to be really good but it's slowly gotten worse as the battery is weakening. If you're standing right next to the car and you still have to press it multiple times, it's definitely time to get a new battery.
Old Feb 28, 2009 | 02:38 PM
NoRicers's Avatar
7th Gear
i got a googlator that allows me to open the hood from an amazing 200 feet away
Old Mar 1, 2009 | 04:28 AM
TLType-s12's Avatar
TL-S izdashiznittt in
Get a VIPER 5901! Can anybody say "one mile range". Youll never be frustrated again.
Old Mar 1, 2009 | 02:27 PM
I hate cars's Avatar
Replacing the fob battery did nothing for me. Replacing a failing car battery made it better for a week and then back to normal. Weird. I've walked 10' away at work and had to turn around and walk back to lock it.
Old Mar 3, 2009 | 10:31 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
I'm experiencing this as well. I'm glad I didn't bother to replace my battery. My A4 keyfob worked literally 50 yards away, for 4 years, on the same battery.
Old Mar 3, 2009 | 10:49 PM
PeterUbers's Avatar
It's not always necessarily the keyfob but its susceptibility to RF interference. In big cities, there's tons of big metal buildings and there is therefore tons of radiofrequency interference. Depends on where you live.
Even with my compustar 2wss (6000 ft range, that's greater than 1 mile for you matho-phobes) in the city i'll get only about 100 ft of range at times. It's all about the interference.
And of course, change your battery as everyone has suggested.
Old Oct 12, 2009 | 03:08 PM
busterdecat's Avatar
5th Gear
Mine is sh*t too. 10-20 ft max and often have to press a few times for it to work. My Acura EL remote was pathetic too but not a bad as this one. I could not take it anymore so changed the battery. Still the same sh*t. Not an ounce better.
Ahhh....I guess there is no fix for it.
Old Oct 12, 2009 | 03:55 PM
tweeder82o's Avatar
Anthracite
sucky the fobs may be, however, after the fobs finally did its job and unlock the doors from 2 inches, you realize that you are now in your tl and driving away; all is well from there...
till you have to walk away and lock your tl with the fob...
Old Oct 24, 2009 | 07:00 AM
rockstar143's Avatar
I wonder if there is a wire for the antenna we can extend. I had this problem with my garage door opener and I crimped on an extension to the antenna wire and the range improved quite a bit.
Old Oct 24, 2009 | 05:29 PM
Waveform's Avatar
'06 NBP TL 5AT NAV
My Llumar tint installer tells me that certain metallic window tints can adversely affect remote key fob performance....
Old Oct 29, 2009 | 11:10 AM
Majofo's Avatar
If it's not the battery then it's definitely interference as suggested. The receiver is in front of the windshield so you want good line of sight to it. Sometimes walking away ~50ft from the TL I can't get it to lock due to the cars in the parking lot blocking the signal path, but in my building I can blip it from +100 yards since I have line of sight.
Alternate issues could be the actual transmitter or receiver. Those issues will be more apparent though. If a new coin battery or reprogramming don't work on the fob, get a new one. If that doesn't work then the receiver / connection is at issue.
Old Oct 29, 2009 | 12:08 PM
Majofo's Avatar
^ also the transmitting freq for most of these fobs is between 300-400MHz in the UHF band. So there shouldn't be much atmospheric or signal interference since the wavlength is < 3 feet, the llumar metallic tint shouldn't be an issue either since the skin depth fade is more apparent at freqs in the GHz range.
Old Nov 4, 2009 | 09:41 PM
georgegiorgio's Avatar
G Force
hold you key fob, right behind your lower head, right above the neck, and press the key, and you'll notice the range
Old Nov 5, 2009 | 07:03 AM
The under head thing doesn't work with this car. It's crazy...sometimes it'll work from close by...sometimes from far. I've also noticed that it'll work from a certain distance, but then you will be standing the exact same spot and click a 2nd time to roll down windows and it doesn't work. Almost like it builds a charge...sends signal and then is very weak!~
Old Nov 5, 2009 | 08:47 AM
Majofo's Avatar
quanaman
Jan 9, 2023 07:33 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
us285126
Oct 2, 2015 02:03 PM
rhdune16
Sep 28, 2015 11:31 AM
h22lude
Sep 27, 2015 06:22 PM
