Howling, grind & groove on inside rotor
I am having this issue at about 45mph and up on the howling sound on the right front, '07 Type S, I bought a new wheel bearing NSK brand and am going to take to my local machine shop, which they quoted $45 to press out old and in with the new. Bring in whole steering knuckle/hub etc...My Question is does anyone know or have had the rotor groove on the inside near towards the center, I am hoping it was from the wheel bearing but it doesn't feel loose.
I might be missing something, but how could a bad wheel bearing cause a groove on the brake rotor? I'd imagine the only thing that could do that is a brake pad
Your Friendly Canadian
Received 1,492 Likes
How are your tires?
I've replaced a wheel bearing thinking it was the source of a highway noise, but worn/uneven tires were the culprit (the bearing needed to be replaced anyway, so not a total waste of time).
Do you have any pictures of the rotor?
I haven't driven it yet, I wound up replacing the bearing-removing the knuckle and taking to pressed out in and in $65.00, then replacing both front rotors and pads. Trying the Advanced/Carquest 2 year rotors and Carquest Wearever Gold pads lifetime. I haven't ever used these so we will see how they are. Thet aren't Ceramic so still going to get massive brake dust but should stop better becaus e I am told Ceramic is actually harder and will wear the rotors even faster. Will get back after a test drive. I do agree on the wheel bearing it seems not related, the pad on the inside was worn to the rivets so it was probably a rivet lodged and groove it deep! But the howling was unbearable.
Definitely turned out to be the wheel bearing, it's quiet now. As far as the pads on the right why they wore so quick, inside pad on right all the way to the rivets. I got an alignment and balance and it is bridging quiet and smooth now.
If you only changed the pads and not the offending caliper, get ready to buy another pad set (AND rotor by that point).
Well I did replace the rotors and pads in addition to the wheel bearing, and a broken ABS wheel sensor that was stuck. The calipers are working smoothly, such as the pistons are not seized. I think the wheel bearing or the alignment had something to do with it. The groove was actually caused by the rivets on the pad.
