How to tighten back bumper
Old Nov 25, 2009 | 09:37 PM
jbacura's Avatar
My back bumper seems to have a gap where it meet the side of the car, is there any adjusment to tigthen this up so it will be flush.
Old Nov 26, 2009 | 07:55 AM
powerflow's Avatar
Wiggy Wiggy Wiggy
You should be able to adjust the plastic brackets that the bumper snaps into.
Also, there might be something bent that's not allowing the bumper to snap into place correctly.
Remove the bumper and take a look. Hopefully you don't find out it was in an accident at some point. You can also check if the bumper is OEM or not. The OEM vin tag is viewable when you open the trunk, on the passenger side jam.
It's very common to see aftermarket bumpers not fitting quite right.
Old Nov 26, 2009 | 08:49 AM
nicourt's Avatar
I had the same problem and originally just pulled out the bumper and used some clear Silicon RTV sealent, using blue painters tape to hold the sides in place till dry. When I upgraded to the 07 base bumper and ASPEC I found that there are two black plastic brackets right under the sides where the bumper mounts...(the place you say thats sticks out) When you pull off the bumper you will see them left and right side.. They are held on by two 10mm screw heads each... If they are loose or not adjusted (slid) more towards the front of the car they will not pinch the bumper clips properly at reasembly.... Sorry I have no pics but I adjusted mine to pinch with no problems.... Good Luck
Old Nov 26, 2009 | 10:04 AM
jbacura's Avatar
Here is a picture of it let me know if this looks normal or need to be tighten.
Old Nov 26, 2009 | 10:47 AM
nicourt's Avatar
If they are not popping out to the right or left I would think you are good... The perfectionist in me might try a bit of adjustment to close the gap a bit....but if you check dealer lots for an average car I'd say again your ok....
Old Nov 26, 2009 | 07:23 PM
jweb12's Avatar
I'm having a similar problem. My car was hit and had to get a new bumper. Ever since, when it's warm out or the car is sitting in the sun, the driver's side of the bumper sticks out (when it's cold, or at night, it contracts back to flush). I think the clips that nicourt is talking about (the black brackets on the side of the bumper just below the tail lights) need to be adjusted, at least for the driver's side. I wasn't sure if there was adjustment in those brackets since I haven't had time to take the bumper off but from what nicourt is saying, it sounds like there is. I'm hoping that takes care of it because it looks terrible.
Old Dec 2, 2010 | 08:28 PM
jbacura's Avatar
I know its been a while but i got around to tightening the back bumper up. It looks better, but now its not flush with the bottom of the lights. I forgot to check to see if this is a oem bumper or not, do you experiece these kind of problems if it was a oem bumper?
niray9
Dec 8, 2015 07:34 PM
IIDXholic
Oct 8, 2015 07:53 AM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
