How to replace a HID igniter?
Old Aug 17, 2011 | 11:42 PM
e5c4p3artist's Avatar
Question How to replace a HID igniter?
Mechanic has diagnosed a bad HID igniter. He recommends replacing igniter and ballast at the same time. I have the front bumper off and the headlight assembly out. I can see the ballast. But where is the igniter? How do I get to it? How do I replace it?
I've searched for instructions on this forum and elsewhere, but I have not found any that show enough detail.
Old Aug 18, 2011 | 11:38 AM
Mafyoso's Avatar
Balling in the...
Ish... A few weeks ago I was commenting on a Post about this same problem and one of the Guys posted a Diagram on how to remove it along with Balast
Old Aug 18, 2011 | 11:39 AM
Mafyoso's Avatar
Balling in the...
Let me keep looking for it and ill post the link here if i do
Old Aug 18, 2011 | 04:44 PM
Here's a question, now that I've been searching all over the net. If I use an after-market HID kit, I won't even have to bother with the igniter, correct? The kit will have it's own?
Old Aug 18, 2011 | 06:29 PM
bbtri's Avatar
A kit should have everything you need. Just do both sides to maintain even color. Once you have the light assembly out replacing the ignitor only takes a few minutes. It's the wire with the component on the end that goes from the ballast to the light. I just replaced mine. I almost used an aftermarket kit because they are cheaper than a new ignitor, but I found a new OEM ignitor on eBay for $70.
Old Aug 18, 2011 | 09:31 PM
Okay, thanks!
So basically, from the research I've done....
Aftermarket conversion kits are cheaper than buying the OEM components. But...
1. To use an aftermarket kit, you'd have to replace the ballast along with the igniter. And no aftermarket ballast has the igniter connection on "top" of the ballast in the same way the OEM does - which means you can't use the OEM hole to connect the igniter to the bulb - which means you have to drill a hole in the headlight assembly to make it work.
2. No aftermarket ballast has the same type of connector the OEM one has to the car wiring, so you have to cut the connector off and splice the wires together.
Does this sound correct?
Of course, I'm still facing the pesky problem of finding a Torx T20 driver with the "tamper proof" hole in the middle either way....
Old Aug 20, 2011 | 12:43 AM
dawgsten's Avatar
Originally Posted by e5c4p3artist
Okay, thanks!
I did it last week - don't bother trying to find a tamperproof Torx driver... haha you'll be looking forever. I just took a small Dremel bit with a cutting head and cut a slot into the head of the bolt and used a slotted screwdriver. Easy as could be
oo7spy
Jun 19, 2023 12:48 AM
pozebly
Sep 23, 2015 07:30 AM
Soul_Deamon
Sep 7, 2015 04:25 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
voigt
Sep 2, 2015 10:44 PM
