how to replace aluminum trim pieces on sides of console?
I just got 2 new pieces of the aluminum trim that run along each side of the center console. I just want to do it the right way without bending the old ones or messing up the new ones. Has anyone done this before? Anything I should look out for? Thanks in advance.
Welcome to the forums.
It's in the 3G Garage
F-052: DIY: how to remove the center dash and the 2 aluminum strips in the center console
https://acurazine.com/forums/showthread.php?t=90964
and here's another thread that's already in the garage (A-086) but will help here
https://acurazine.com/forums/showthread.php?t=130713
http://home.usadatanet.net/bclaps/TLAuxcableinstall.pdf
(How much did the two trim pieces cost you and where did you get them?)
As for installing, go get a knife, rap a thin cloth around it, and then you can slip the knife in between the trim pieces and the area around the A/C buttons and slowly lift. If I'm not mistaken, there are three or four strong clips holding them in.
ulrblitzer
09-24-2015 07:42 PM
