How to remove the rear seat?
Old Mar 6, 2011 | 05:34 PM
deepblue626's Avatar
i have an 05 tl. i want to check my rear speacker. can someone gave me an step by step procedures
Old Mar 6, 2011 | 05:55 PM
dinks07's Avatar
There are 2 bolts inside the rear headrest. 2 bolts on the bottom and one on the bottom cushion and it pulls out
Old Mar 6, 2011 | 06:12 PM
i can not get to the 2 bolts indie the rear headrest
Old Mar 6, 2011 | 06:16 PM
EL PESADO's Avatar
You'll need a 10mm socket with a ratchet extension to reach the bolts beneath the seat bottom. Ready?
If you're facing the back window, there is a bolt at the right side of the armrest (between the seat back and seat bottom) Spread the seat bottom and back with your hand and you'll see it bolted to the metal floor of your TL. That bolt is holding a little metal arm - remove that bolt. Now pull up on the front parts of the seat bottom and pop the 2 clips that are holding the seat bottom (1 clip in front of left & right side). IMPORTANT: Make sure you remove the bottom of the seat before the back or you'll scratch your leather with the metal parts of the seat back!!! Pull the seat bottom out of the car and remove the 3 remaining 10mm bolts that are holding the seat back to the floor. See those 2 big metal tabs on the bottom? Careful you don't scratch your paint when you take that out of the TL.
Now take the seat belts and swing them around so that they're behind the seat back. Push up on the whole seat back - towards the ceiling - to remove the 4 large clips that are holding the seat back to the rear deck. This is the hardest part! Just take your time! Pull the back out of the car and you'll see your trunk and your sub amp behind the right side seat. Let me know if you need anything else buddy!!!
__________________
Old Mar 6, 2011 | 06:34 PM
it's is late i'm gona try it out some other day. i did all beside the " Push up on the whole seat back - towards the ceiling - to remove the 4 large clips that are holding the seat back to the rear deck." can u please let me know where is those 4 large clips and how to find them?
Old Mar 6, 2011 | 10:52 PM
Bearcat94's Avatar
AZ Community Team
F-070: DIY: How to remove the back seats to put the suspension?
https://acurazine.com/forums/showthread.php?t=107568
All this basic stuff is in the 3G Garage - often with Service Manual scans, pics and tips. You guys that have been around here for a while should know this.
If you're gonna work on your 3G, book mark this link: https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-garage-faq-3g-tl-newbies-553554/
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
d.lim
Sep 15, 2015 08:54 PM
EE4Life
Sep 11, 2015 10:13 PM
truonghthe
Sep 7, 2015 11:17 PM
