How to remove ebay rear deck spoiler?
It depends on if it was put on with, bolts (drilled into deck lid), or stuck on with 3M tape. If it was drilled then it will be a headache because then you will have holes in your deck lid. If it was stuck on with 3M tape, i woukld take a blow dryer, heat up the tape, and then try to remove it slowly from one end (dental floss helps). Search the forums on how to remove the badges from your trunk lid, essentially the same process if its on with 3M tape.
cycdaniel
12-17-2019 10:58 AM
09-04-2015 08:03 AM
