How much should I expect to pay for B24 service?
Old May 26, 2013 | 10:56 AM
harveyk's Avatar
8th Gear
My '04 TL is overdue for the B24 service. Specifics (right from the owner's manual) are listed below. I assume the most costly item is the timing belt replacement.
Money is REALLY tight for us these days -- I was out of work for six months -- so while I know I've got to get this done, it's imperative I don't pay more than I have to.
Incidentally, we live in Owings Mills, MD, a suburb of Baltimore.
Your opinions/advice is greatly appreciated! Thanks!
Oh, by the way, I'm completely inept when it comes to anything mechanical, so please don't suggest I do any of this myself.
B
Replace engine oil and oil filter
Rotate tires
Inspect front and rear brakes
Check parking brake adjustment
Inspect these items:
  • Tie rod ends, steering gear box, and boots
  • Suspension components
  • Driveshaft boots
  • Brake hoses and line (including ABS)
  • All fluid levels and condition of fluids
  • Exhaust system
  • Fuel lines and connections
Replace air cleaner element
Replace dust and pollen filter
Inspect drive belt
Replace spark plugs
Replace timing belt and inspect water pump
Inspect valve clearance
Old May 27, 2013 | 02:26 PM
carz0159's Avatar
Probably around 1500$, but I could be a little off.
Old May 27, 2013 | 04:46 PM
TLtrigirl's Avatar
3G TL/2G MDX Owner
isn't this a repost?
short answer: $800-1600 depending if it's an indy or a dealer.
Old May 28, 2013 | 05:06 AM
tonto340's Avatar
Anderson Honda in Cockeysville has a timing belt special for $389.95.
Aug 15, 2019 12:58 PM
TypeSJeff
Sep 22, 2015 01:34 AM
Mr.Tea
Sep 14, 2015 09:58 PM
asahrts
Sep 4, 2015 05:55 PM
