how do u remove headlights??????
just wondering if u have to remove the front body kit to remove the headlights? and also is there a way to make the HIDs blue'er? is there bulbs that u can replace?
Land of 10,000 lakes
You'll have to remove the front bunper cover to get access to the headlights. There will be about about 7 bolts holding in the headlight and two more holding the ballast bracket to the frame which are a PITA to get to. If you want "bluer" headlights look into some bulbs that are D2S atleast 6000k or higher Kelvin rating. You're cutoff line should provide enough of that "blue" look your looking for though. Also, keep in mind that the higher the Kelvin rating the lesser the output. Optimally 4300k is what you want.
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
