How to check the IAT probe
Old Jan 23, 2007 | 06:53 PM
Beniot's Avatar
6th Gear
Hi,
I suspect that my IAT probe could be defective, i.e. giving a temperature that is too high or too low, but not enough to trigger the check engine light.
Does somebody know how to check it ? for example, if I unplug it, what resistance should I read at room temperature ?
Thanks in advance,
Old Jan 24, 2007 | 10:56 AM
bhelsdon's Avatar
if you have access to a scan tool it would be easy to check. With the car completly cold(ie before it is started in morning) plug in the scan tool and read what the iat senor is showing. if it is the same as the outside air temp then it is working.
Mike Pilipenko
Mar 26, 2024 09:21 PM
MilanoRedDashR
Oct 8, 2015 10:30 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
Skirmich
Oct 1, 2015 12:59 PM
hrothgar02
Sep 28, 2015 11:08 AM
