How can I figure out where my power steering leak is coming from
Registered but harmless
Received 1,150 Likes
Open the hood and follow the hoses from the PS fluid reservoir to see if one of them is leaking.
Raise the car (preferably on a lift) and see if you can trace the leak.
You may have to clean off the engine to trace the leak if the engine is really dirty.
From the sound of your post, it may be better to have a mechanic look for the leak; the mechanic can show you where the leak is if found.
BTW, all 3G TL models were recalled for replacement of the high-pressure side PS hose as well as the low-side O-ring. Best to check with an Acura dealer to see if your car's VIN is listed as "recall completed." There is a fire hazard if the high pressure hose leaks.
guyenacurazine
04-28-2016 03:29 PM
