How to adjust hood alignment
I searched.
Can anyone tell me how to adjust the hood alignment? Basically the gap on the left is wider than the gap on the right. This is with a VIS CF hood.
Might want to try tweaking the hood hinges and front latch and hood hook if needed. Depending on how much you need to move the fenders, you could throw off the gap around the headlights. Also, loosening the headlight will help to adjust the fender on the front area.
To be clear, I want to adjust the hood hinges, not the fenders. I thought (and still do) that Turbonut was describing how to adjust the hood hinge alignment, not the fenders. Am I right? The fenders are definitely fine, the car is straight no accidents. The issue is just the CF hood needs adjusting. Thanks!
emailnatec
29
Sep 28, 2018 04:27 PM
Jul 16, 2017 07:33 AM
